RagunCajun Posted April 3, 2016 Author Report Posted April 3, 2016 What exhaust springs are people using for big bore in frame shearers? The newer is OEM and im not sure which kind my old ones but it seems the top one needs to be longer. http://s240.photobucket.com/user/raguncajun/media/DSC02091_zpsmqoefl4w.jpg.html I also need to order some orings for the flange. I ripped two so far. I have my last one stretching over night so it fits. Quote
bluebanshee98 Posted April 3, 2016 Report Posted April 3, 2016 To stretch out springs use stock pegs hole. Put stock pegs on bike. Insert one hoop and then you use spring puller tool and slowly stretch it out. Don't go too far when stretching. You want it long enough so that you still need to put some effort to pull the spring on to the pipe 2 Quote
lastnline75 Posted April 4, 2016 Report Posted April 4, 2016 To stretch out springs use stock pegs hole. Put stock pegs on bike. Insert one hoop and then you use spring puller tool and slowly stretch it out. Don't go too far when stretching. You want it long enough so that you still need to put some effort to pull the spring on to the pipe^^this..works everytime. FKN JUNK 1 Quote
RagunCajun Posted April 4, 2016 Author Report Posted April 4, 2016 Will do. Thanks. I have to order some orings tomorrow for the exhaust flange. I ripped two orings trying to put the pipes on. I got one in and the last oring i have is stretching a little over night. I want spares. Starting to look like a banshee somewhat: Thanks again for the people who noticed i originally got the wrong shocks. I'm going to have to get some exhaust wrap for the stingers. They will for sure melt the air filters. I really wish Shearers fit better. It may take some massaging so they expassion part does hit the frame at the bottom. Quote
sheerider11 Posted April 4, 2016 Report Posted April 4, 2016 I'm not going back through the thread, what color is that frame? Quote
Strm Trpr Posted April 4, 2016 Report Posted April 4, 2016 You're welcome on the shocks... Shoulda got Snipers for your SS!! 1 Quote
LaegerEliminator Posted April 4, 2016 Report Posted April 4, 2016 Are you using grease on the o-rings and on the your pipes where they slide over the exhaust spigots during installation? Quote
bluebanshee98 Posted April 4, 2016 Report Posted April 4, 2016 Use cascade heat wraps. They look good ( for wraps that is) and do a good job Quote
RagunCajun Posted April 16, 2016 Author Report Posted April 16, 2016 I'm not going back through the thread, what color is that frame? Oil rubbed bronze. You're welcome on the shocks... Shoulda got Snipers for your SS!! I talked to redline about this last week while ordering stuff. I'm sticking with my shearers. I also didnt know they made big bore inframe snipers 2-3 years ago went i had this engine built/dynoed. I may engine up getting a set late this year or next and sell whatever pipes i dont like. There's a small market for BB inframes though. Id lose a good bit of money. Are you using grease on the o-rings and on the your pipes where they slide over the exhaust spigots during installation? I ordered some different(read as "the correct") orings and the pipes went right on. Evidently i picked up the wrong ones a long time ago. Use cascade heat wraps. They look good ( for wraps that is) and do a good job I went with exhaust wrap. Turned out decent enough considering it wont be scene. Here's how it ended today. http://i240.photobucket.com/albums/ff111/raguncajun/DSC02098_zpsiqsppskk.jpg http://i240.photobucket.com/albums/ff111/raguncajun/DSC02099_zpsv7anlshn.jpg http://i240.photobucket.com/albums/ff111/raguncajun/DSC02100_zpsgrokwu78.jpg I cant believe i dont have the nut that holds the front sprocket on. No telling where that thing went to. So ill be ordering that this weekend. That's why the stator/flywheel cover is off. I'm still waiting on a front replacement rotor i messed up as well. I have to take off the clutch side cover and adjust the pancake bearing. There's too much tension on the clutch when it's hooked up to the lever on the handle bars. If i remember right, you can back the nut off and turn the screw in the center to let some slack out. It's a cascade pancake bearing or whatever it's called. Once that's done i have to install and hook up the junk looking piece of shit stock thumb throttle i have. I will use the stock one until i can find a Honda thumb throttle off a 250r then get the logo milled off then powder coat everything. I read that's the best. I'm not spending a fortune on the Cuervo racing one. Then ill fire it up hopefully tomorrow around lunch time. I've never heard big bores in person so im looking forward to that most. Quote
bigweav81 Posted April 16, 2016 Report Posted April 16, 2016 Oil rubbed bronze. I talked to redline about this last week while ordering stuff. I'm sticking with my shearers. I also didnt know they made big bore inframe snipers 2-3 years ago went i had this engine built/dynoed. I may engine up getting a set late this year or next and sell whatever pipes i dont like. There's a small market for BB inframes though. Id lose a good bit of money. I ordered some different(read as "the correct") orings and the pipes went right on. Evidently i picked up the wrong ones a long time ago. I went with exhaust wrap. Turned out decent enough considering it wont be scene. Here's how it ended today. http://i240.photobucket.com/albums/ff111/raguncajun/DSC02098_zpsiqsppskk.jpg http://i240.photobucket.com/albums/ff111/raguncajun/DSC02099_zpsv7anlshn.jpg http://i240.photobucket.com/albums/ff111/raguncajun/DSC02100_zpsgrokwu78.jpg I cant believe i dont have the nut that holds the front sprocket on. No telling where that thing went to. So ill be ordering that this weekend. That's why the stator/flywheel cover is off. I'm still waiting on a front replacement rotor i messed up as well. I have to take off the clutch side cover and adjust the pancake bearing. There's too much tension on the clutch when it's hooked up to the lever on the handle bars. If i remember right, you can back the nut off and turn the screw in the center to let some slack out. It's a cascade pancake bearing or whatever it's called. Once that's done i have to install and hook up the junk looking piece of shit stock thumb throttle i have. I will use the stock one until i can find a Honda thumb throttle off a 250r then get the logo milled off then powder coat everything. I read that's the best. I'm not spending a fortune on the Cuervo racing one. Then ill fire it up hopefully tomorrow around lunch time. I've never heard big bores in person so im looking forward to that most. Is that oil rubbed bronze powder coat? sent from yo mammy house. Quote
Scrubby Posted April 16, 2016 Report Posted April 16, 2016 Next time you put the heat wrap on, soak it first, and pull it tight, it will mold to the pipe better, holds the tag end better too. Quote
RagunCajun Posted April 17, 2016 Author Report Posted April 17, 2016 I will redo the wrap. I don't like how uneven it is. I want to install my Cascade innovations exhaust clamps too. Thank you. The powder coat color is oil rubbed bronze. And quoting an entire big post like that makes it harder for mobile users. Same reason I don't use image takes usually when posting picture. I also will install my Cascade seat cover tomorrow too. I also forgot to mention the next thing to order brembo rear caliper. Quote
bigweav81 Posted April 17, 2016 Report Posted April 17, 2016 I was just curious. I had mine sprayed with an oil rubbed bronze we use on our tank batteries. Nice build by the way. sent from yo mammy house. Quote
RagunCajun Posted April 17, 2016 Author Report Posted April 17, 2016 Does my color look the same? I assume the color will vary from coater to coater. My guy said this is the first thing he sprayed this color besides patio furniture. Quote
bigweav81 Posted April 17, 2016 Report Posted April 17, 2016 Mine isn't powder. More of a dark charcoal grey with metallic, and doesn't look near as good as yours. I'm going to powder coat a newer frame when I get one. That or cut the subframe off, and buy a removable. The color you have is what I want. Look good with my gold wheels lol. sent from yo mammy house. 1 Quote
