Ok so I changed the clutch cable and took off one of the carbs to make it easier to do didnt touch anything on them put the carb back in the boots and now it wont run and if I get it to run it wont idle any ideas on what could have happened bike was running mint before
yup ran fine with ittoo just one i changed the clutch cable its a pain to start and wont idle it was always a one kick bike since i got it a couple weeks ago
the thumb throttle assembly I have now the adjustment screw is broken i ordered another one a few days ago should be here monday I thought that might be the problem because if you hold the cable out just a hair it ran same thing if u pull the choke out a hair
Edited by Vincip92
Check that cables are seated in top of carbs, and in cable splitter. Double check EVERYTHING. Check float levels. It's got to be something simple YOU did putting cable on. Check that choke tube isn't cracked, broke, dryrotted, and that it is on BOTH carbs securely.
was away for the weekend just got back checked the choke tube had a crack on the end changed it and will test it tomorrow hopefully that will be the fix thanks
its back to runnin fine and i couldnt start it when i put it on my neighbors hate me as it is starting that at 11 at night wouldnt be good they called the cops on me the day i got it just driving it off my truck into my garage.
