03DMshee
Everything posted by 03DMshee
  1. A buddy of mine picked up a banshee so we decided to open it up to give it a once over. ...im never ceased to be amazed. ...
  2. Ok deployed i will give you ....(and thank you)
  3. Really? Cause i know i work on my banshee whenever the fuck i want.....
  4. Id nicely jesture to my dick and tell her she knows where her dinner hangs as your walking out to shop! Hahahaha
  5. Is that tag on your handlebar for you toe when you smack a tree?
  6. Eh....you right....12999 should take it
  7. Only in 88 model...
  8. DMC also has a spark arrester/hush kit too...also a good pipe for trails
  9. Just becuase those arrows are lined up doesnt mean its perfect....
  10. Dont shift at high RPMs between first and second gear. ..ride all day...wanna miss a whole ride? Or you wanna just take it easy and get your ride in?
  11. Well what jetting is in "known good" carbs? And is your choke tube between the carbs attached?
  12. Why is the grass always wet?
  13. http://bansheehq.com/forums/index.php?showtopic=176326&page=3#entry1624120 Check that out...might give ya heads up if you didnt already have one....
  14. I dont make sense? Or him calling his banshees girls dont nake sense?
  15. Looks like there off of a 1932 model A....gonna take a hell of a resto to bring those back...unless your build is gonna be "pitina"
  16. I beleive he is referring to his 2 "banshees" as his "girls"
  17. Looks like you got your work cut out!
  18. Didnt even have to read past the second post....
  19. Pictures of said girfriend...topless gets extea scene points....
  20. Unless something changed on ALBAs side those adaptors are a good idea with poor execution...i ended up having to buy longer shocks to run those arms...if you look at the picture of them on the banshee you can ckearly see they are not made the same side to side...on the right side of the banshee you can see the lower shock bolt wheres as the left side it is blocked by the lower arm. ...just a heads up if your gonna run standard travel.... As far as the construction of the arms they are fucking awesome if you run a longer shock... AlBA has also been great customer service wise...replaced my bushings for free and even included new sleeves!
  21. Make sure you name it "head and shoulders build" in the images section!
