Crooked studs help fix
4/10 head studs crooked. When the big bore sleeve was installed you have to re tap the stud holes. Well your tapping a hole that's 1/3 steal 2/3 alum some were done wrong. Could I just drill, tap helicoil the hole straight on a Bridgeport mill? My father a machinist says that won't work.
Well eBay (trinity) did the jugs lol couldn't pass up 100 for the set. Crooked studs = 100 bucks. I fixed em and 4mil ported for trail/drag 80-85hp by hjr. I had to put the studs in after hjr sent em back. That's when i saw wtf studs! I just tapped them with a hammer till the head goes on by hand. Problem solved.
