bjd626
Everything posted by bjd626
  1. Ok just got it all back together,took it for a test spin get back in the shop and it's leaking coolant from two of the studs on the bottom. But I do not see any in the oil.any ideas as to why? Suggestions
  2. Their number has changed (951) 734-7433
  3. Thanks for the help
  4. Juan and Amigaos they sold out to eyeball engineering
  5. Can anyone recommend a machine shop to send my cylinders to in the so.cal area? I'm in need of a bore
  6. Perhaps a larger assembly hammer?
  7. Big red 350x the walk through is great. I just can't see on the picture of the dowels if the one on the stator side is in the same position as the two in the middle, or does it go in the bottom case?
  8. Thank you very helpful
  9. I guess this is a forum to improve grammar.my mistake I was under the impression it was a banshee forum maybe you could help me with both?
  10. I split the cases and found the bearing on the stator side cracked and the had been put into the hole in the cases this is my first rebuild the pin was pulled out of the crank bearing I'm guessing that's what caused the cracked bearing does it go in there or sit like the two in the middle bearing
  11. Stock motor other than k&n filter t3 's two into one carb about 2,900 ft. And ya California gas
  12. What size domes should I use running pump gas
  13. does it need anything or is ready to Drop in and go Sent from my SM-G900V using Tapatalk
  14. Has the transmission sold Sent from my SM-G900V using Tapatalk
  15. Do you still have the tranny? Sent from my SM-G900V using Tapatalk
  16. I don't have any info on boris any help and direction will be greatly appreciated Sent from my SM-G900V using Tapatalk
  17. Any one know of a good shop to go to to get bearings pressed on and off my crank and maybe do some boring also I'm in so. California outside of Palm Springs or if I have to ship my stuff I'm just looking for someone who knows what they are doing Sent from my SM-G900V using Tapatalk
  18. I'm talking about the one behind the clutch basket Sent from my SM-G900V using Tapatalk
  19. With the two screw that hold it in place ? Sent from my SM-G900V using Tapatalk
  20. Any one know how or why pulled my motor apart found the bearing stopper plate snapped in half cracked race on main bearing Sent from my SM-G900V using Tapatalk
  21. How much for transmission? Sent from my SM-G900V using Tapatalk
  22. How much for the crank Sent from my SM-G900V using Tapatalk
