Banman1122
Everything posted by Banman1122
  1. The internal adjuster should have a hair of free play ensuring the clutch in fully engaged. Then you take up the slack on the perch until the marks line up to ensure a full disengage. If after that it's still goin past the marks your perch is pulling the cable too far. Sent from my iPhone using Tapatalk
  2. Bump.... Been seeing questions on this lately. Sent from my iPhone using Tapatalk
  3. I've never had a stock machine but a 5 psi diff is a sign of rings are worn. Sent from my iPhone using Tapatalk
  4. Sounds like it's blown up. Sent from my iPhone using Tapatalk
  5. Pwk 39mm. Only 200 each new and you may find some on here used. Sent from my iPhone using Tapatalk
  6. Sounds like the head gasket blew due to overheating. Check water pump. Sent from my iPhone using Tapatalk
  7. ^^^^so true! Sent from my iPhone using Tapatalk
  8. I would flip out and throw the constitution at their face and scream privet property rights. Some machines just can't be quiet. Sent from my iPhone using Tapatalk
  9. Lol the key word "trinity and eBay" rofl. The story behind the problem of crooked studs doesn't tell you how to fix them. It's how have they been fixed in the past and what works and what doesn't work. Sent from my iPhone using Tapatalk
  10. Ok I'm hittin 300 ft this weekend. I'll take my 14 15 and 41 40 and 39 with me too. I don't have a lock up or cut tranny yet. If that makes a diff. Sent from my iPhone using Tapatalk
  11. 39mm pwks, 18cc domes, 180 psi, 104 oxy fuel, rdz oof sb pipes, +6.5 timing Sent from my iPhone using Tapatalk
  12. 300ft Sent from my iPhone using Tapatalk
  13. With a lock up you can't pull the lever in when your in the top rpm range. That's why you need a cut tranny to up shift without pulling in the lever. You'll have to let the rpm drop to pull in the lever to down shift with a lock up and cut tranny. Your mx riding a lock up would not be good. Sent from my iPhone using Tapatalk
  14. I got a 421 hjr porting 80-85hp +8 swinger 67ro 11paddle haulers. What would appropriate gearing? Now is 13/42. Sent from my iPhone using Tapatalk
  15. Well eBay (trinity) did the jugs lol couldn't pass up 100 for the set. Crooked studs = 100 bucks. I fixed em and 4mil ported for trail/drag 80-85hp by hjr. I had to put the studs in after hjr sent em back. That's when i saw wtf studs! I just tapped them with a hammer till the head goes on by hand. Problem solved. Sent from my iPhone using Tapatalk
  16. R/O on the haulers? I'm very interested! Sent from my iPhone using Tapatalk
  17. I'll use a carbide drill and a cobalt tap. That should follow straight cutting half cast iron and half alum. Sent from my iPhone using Tapatalk
  18. I'm thinking set the jugs up on the Bridgeport then drill tap helicoil. They are only off .01 and head goes on hard with a deadblow hammer. Sent from my iPhone using Tapatalk
  19. I talked to herr jugs and he said sense I can get the head on with a rubber mallet to just put a nut on the stud and wack it with a hammer. Sent from my iPhone using Tapatalk
  20. 4/10 head studs crooked. When the big bore sleeve was installed you have to re tap the stud holes. Well your tapping a hole that's 1/3 steal 2/3 alum some were done wrong. Could I just drill, tap helicoil the hole straight on a Bridgeport mill? My father a machinist says that won't work. Sent from my iPhone using Tapatalk
  21. Who gets porn mags these days. How about a membership to a porn website. Sent from my iPhone using Tapatalk
  22. I'm from southwest Michigan in a town called Buchanan. Sent from my iPhone using Tapatalk
  23. Lol I run cpi inframe drag pipes for the trail. Sent from my iPhone using Tapatalk
  24. I'm in south west michigan and I will be goin to this if you wana come out. Sent from my iPhone using Tapatalk
  25. Yes I'm sure the flywheel and mid bearings are 8 ball and the gear side is the tz. And ya know what I got my parts and in speedy time. Fastest trail riding machine in the area that has 85hp. I can run 30-40 min rides in the trails and down the road all day long. Say what you want it won't change the fact I did what I did and got what I have from a guy that's done nothing to me like you say he's done to others. Y'all prolly drank the cool aid and don't even know the real story. Just regurgitate what you've heard like a bird feeding it's young. Sent from my iPhone using Tapatalk
