my banshee is throwing a piss fit. yesterday it fired up 2nd kick idle perfect and stalled for no apparent reason. i kicked it about 5 or so times its kick back and re adjusted my foot. now all it does is pop not like a back fire. changed plugs cleaned carbs checked reeds has spark ect.
Same boat here Corey. Just did cdi swap, checked the woodruff key, checked the pick up, new plug boots, ground(s) are good, carbs are mint, good fuel, new plugs, ohmed the stator, and leak down. It seems to spark fine on both sides but just won't fire. I am hopefully going to swap the coil tonight and re do the grounds again.
If it doesn't fire, I'm just doing a new stator, pick up, coil, cdi.
tricked when i had this on alcohol last summer one day it would start first kick next day it would just pop and id have to push start it next day fire right up ect im think maybe the cdi is taking a shit because sometimes while riding it it would randomly stutter like like a stutter box >
Check the caps? Coil? Stator? With an ohm meter?
stator was in spec according to clymer i cut the wirs down a little on the coil to get fresh wire and still nothing
