Swinger bolt is stuck! Any ideas
Spin it with an impact gun. I have an Ingersoll Rand 2135 Titanium 1/2" impact, it's 1000ft/lbs in reverse @100psi it will definitly break that bolt free, or spin the bearings in the swingarm lol! DO NOT heat it, it will change the temper of the steel the swingarm is made out of, weakening it.. As far as getting the bearings out go talk to your local Snap-On tools dealer, and buy Part# A78 Pilot Bearing Puller.. It works AWESOME on swingarm bearings and wheel bearings, or any other bearing that is pressed into a bore. Or if you don't care about the swinger, use an Oxygen/Acetelene cutting torch and cut swinger pivot in half and pull it out in 2 pieces.
