Mad_banshee_racer
Mad_banshee_racer's Achievements
  1. What about spraying the head gasket down with some copper sealant spray?
  2. Did leakdown test, and failed it the head gasket. So I replace head gasket and it failed again wtf?
  3. 20 bucks
  4. I'm may be interested in the carbs. Looking for some to set up for e85
  5. I was thinking about going to busco this weekend myself
  6. I'm getting the same setup done now on my 87 shee, you really need to get the jugs ported for the 4mill hell with the plate. And yes custom cut domes. I'm getting Kevin at herr jugs to do mine.
  7. Looks real good, I'm thinking of tearing my 03 down this winter and powder coat the frame blue. This is a picture of my 87 project I need some new foot pegs
  8. I need a set of 39 set up for e85 on a drag bike I'm building
  9. A 3500 pos, make a offer of 1200 because its the kick starter model. Haha
  10. Your right I should have done a leak down test when I put it back together. I really didn't know what a leak down test was until the other day. I was hoping to have this fixed by the weekend.
  11. I still need to build a leakdown tester, guess I can go by lowes today.
  12. I'm going to put a new head gasket on and will do a leakdown test the same time.
  13. It all started after I had some port work done by herr jugs and my head milled. Should be a good flat surface with the freshly milled head. I have a oem head gasket still in the pack that I'm going to try.
  14. No I think it's only one hose, it runs from the reservoir.
  15. Maybe a bad cap, I can compress it. When you say leak in the system should I see it? I can see what looks like some black carbon it the coolant floating around.
