Hope you know what you are doing. This is one area I would hate to have fail on my bike. I have a good friend that found out what happens when a suspension component cuts loose on a wide open run. I went and put new ball joints and tie rods on all my bikes after that accident. You could get a set of used ones or at the least go with a set of YFZ arms for minimal cost.
If you ball joints are done then just save up over the winter for some +2+1 arms, you usually can find a nice set on here or ebay for cheap.
I cut and welded my a arms as well I did not change my ball joints thou I cut them back at the tube whre they meet to the frame and made them 2 inches wider and 1 inch forward per side.
I also relocated my shock mounts on the a arm ot change the stiffness and ride height. works great
I have a this now for a few years with no problems I ride real rocky areas and do some jumps. the quad has taken a beating.
thats not to say it won break next time.
I have also cut and welden my footpegs moved them back about 2 inches along with my rear brake and shifter
measure twice and cut once good luck
Edited by lms1977
this has been done already thought there was a write up on it also TIM at STELLAR machine is selling the ball joints and will include the mount bullets threaded for them. i think he said around 100 bucks for all 4. not bad. last write up i read the guy got them in and they worked fine. good cheap alternative to +2's
i think there was even a youtube vid on it. another thought- whay not just go heims?.... you can get them the same, or cheaper, plus you don't have to buy bungs if you can make the longer bungs yourself......
That part # youre looking for is es2074r, its a heim joint off a subaru brat. The main threaded part is 14mm, and the spindle pin is 10mm. I used them on my burgard a arms, and they are fine. Props to NYUK for giving me this number when I was looking for it. In fact I renamed my dog es2074r, so I wouldnt forget it.
You will have to ream your spindles to make these fit.
Can I just order them at NAPA? Or do I have to get them online?
This Is The part you should give to the parts store
Part #: MOES2074R
And this the manufacture's number either should work and i did find them online as well
Mfr #: ES2074R
Just do it, it will be fine. Anyone can weld better than a Japanese robot.
Actually the majority of the manufacturing for these bikes takes place right here in the USA. I believe their plant is in the midwest somewhere.
starting working on them today. i notched out the lower shock mounts to accommodate the yfz shocks im using. also went to NAPA and ordered the moog tie rod end ball joints. really digging into the arms tomorrow to get them set up for fabrication. also, what do i need so i can ream out my spindles?
you need a tapered ball joint reamer, their not real cheep but the only way to do it right, or take them to a machine shop in your area they may have a set and would probably cost less to pay them to do it than you could buy the reamer for.
