shawn941 Posted January 22, 2010 Report Posted January 22, 2010 just went through my second aluminum shifter. i spent $60 on my last billett shifter and the damn things keep vibrating loose and end up stripping the splines. the splines on the shaft itself are still in great condition,,,luckily i guess.my last shee had a stock steel shifter and never had this problem, i even used locktite on it and helped somewhat i guess. thinkin about buyin the steel ims shift lever this time,,,what is everyone else running,,steel or billet? Quote
04trinityshee Posted January 22, 2010 Report Posted January 22, 2010 just went through my second aluminum shifter. i spent $60 on my last billett shifter and the damn things keep vibrating loose and end up stripping the splines. the splines on the shaft itself are still in great condition,,,luckily i guess.my last shee had a stock steel shifter and never had this problem, i even used locktite on it and helped somewhat i guess. thinkin about buyin the steel ims shift lever this time,,,what is everyone else running,,steel or billet? i have the steel ims shifter and it does the same thing i even tightened the bolt as tight as i could without snapping it and then put a nut on the bottom side to try and keep it together it worked for a little while but now its back doing it again Quote
shawn941 Posted January 22, 2010 Author Report Posted January 22, 2010 i have the steel ims shifter and it does the same thing i even tightened the bolt as tight as i could without snapping it and then put a nut on the bottom side to try and keep it together it worked for a little while but now its back doing it again ya,,,i tried yhe same thing with the same results,,,,lol Quote
spurdy Posted January 22, 2010 Report Posted January 22, 2010 ya,,,i tried yhe same thing with the same results,,,,lol I've had aluminum shifters on my last 2 banshees and have never had an issue. With stripping splines or with the bolt coming loose. Don't know what to tell you accept check it and re tighten more frequently. Predictive maintenance as well as preventive maintenance. SP Quote
jamebo Posted January 22, 2010 Report Posted January 22, 2010 If your looking for a little bling with reliability, you could go with a chromed stock shifter. I purchased one off of ebay awhile back and it's working out really well, and looks great. Quote
shawn941 Posted January 22, 2010 Author Report Posted January 22, 2010 I've had aluminum shifters on my last 2 banshees and have never had an issue. With stripping splines or with the bolt coming loose. Don't know what to tell you accept check it and re tighten more frequently. Predictive maintenance as well as preventive maintenance. SP thats the thing,,,,,its not the bolt loosening. the bolt will be just as tight as when u intstalled it but the shifter is loose. and its not that im not checking it frequently enough,,,,it loosens like this within in hour of riding.....no problems on my last shee with stock shifter. gonna try one more aluminum one Quote
87sheerips Posted January 22, 2010 Report Posted January 22, 2010 Steel is the only way to go. Ive had issues with Aluminum in the past. Quote
shawn941 Posted January 22, 2010 Author Report Posted January 22, 2010 Steel is the only way to go. Ive had issues with Aluminum in the past. so your running a stock shifter or aftermarket? Quote
BigRed350x Posted January 22, 2010 Report Posted January 22, 2010 I've had aluminum on all my bikes without any issues. Maybe try a lighter tension spring on the shift shaft and shift star roller, to make the movement easier, so you're not putting so much pressure on the shifter to change gears. That's the only thing I can think of that would make the aluminum ones wear out faster. Remember the aluminum is softer than the steel of the shift shaft, so its going to wear faster, especially if you like to stomp on your shifter lever. (never understood the people that do that) Quote
bbcmudtruck Posted January 22, 2010 Report Posted January 22, 2010 Are the splines on your shift shaft in good shape? Quote
shawn941 Posted January 22, 2010 Author Report Posted January 22, 2010 Are the splines on your shift shaft in good shape? yes,,,the splines on the shaft are in great shape Quote
BSHEE400 Posted January 22, 2010 Report Posted January 22, 2010 i've been running the steel ims one for two years now and it has never come loose, i do check it frequently just to be safe Quote
g-force Posted January 22, 2010 Report Posted January 22, 2010 It's not that the bolt is coming loose, It's that when you tighten the bolt all the way the shifter is still to loose. I had to use a hacksaw blade and remove some material from the gap where the bolt goes through. It hasn't come loose since. Quote
FrankieSquid Posted January 22, 2010 Report Posted January 22, 2010 If your looking for a little bling with reliability, you could go with a chromed stock shifter. I purchased one off of ebay awhile back and it's working out really well, and looks great. Im looking to consider this because i went through a billet shifter and the damn Splines stripped out and the bolt broke on me once. I just had bad luck with these things. The brass splines strip out quick. Either i might try another but the stocker chrome sounds like a good idea. Quote
sinisterboo Posted January 22, 2010 Report Posted January 22, 2010 Nobody has even bothered to consider maybe its getting the shit stomped out of it! My wife does that when her bike pisses her off. its pretty funny to watch! can we get a video of you riding??? LOL p.s. you dont wear size 16 shoes do you??? Quote
