bobdryerr Posted August 31, 2009 Report Posted August 31, 2009 Ok my bearings in the swingarm where it bolts to the frame are bad. So I got it all torn down an have the new parts but I just can't get out the old ones. All that's left in there is the outer part of the bearings an I've tried searching on here an google and couldn't find anything that might help me. Any help would be awsome thanks ladies an gents. Quote
bbcmudtruck Posted August 31, 2009 Report Posted August 31, 2009 Chuck it up in a vice and get a long piece of bar stock or pipe that will fit all the way through the swing arm and beat the crap out of it! Quote
bobdryerr Posted August 31, 2009 Author Report Posted August 31, 2009 Chuck it up in a vice and get a long piece of bar stock or pipe that will fit all the way through the swing arm and beat the crap out of it! I've tried that but there's that lip on the inside an it hits agianst that an it won't go any further. Quote
fastbanshee8 Posted August 31, 2009 Report Posted August 31, 2009 I've tried that but there's that lip on the inside an it hits agianst that an it won't go any further. There shouldn't be a lip on the tube that the bearings go in. Those needle bearings are encased with metal, so maybe that's what you are seeing. The bearings do not come out very easy at all, especially if they are completely worn out, or coming apart. Quote
slamed91si Posted August 31, 2009 Report Posted August 31, 2009 if they are all worn out beat a flat head screw driver in between the bearing and swing arm and pry up and bend it till it comes out or use a die grinder and cut it out Quote
sleeper06 Posted August 31, 2009 Report Posted August 31, 2009 Snap on makes a bearing puller,its like a slide hammer with adjustable nose peices for diffrent jobs,its bailed me out on more than one occasion Quote
speedcrazyshee Posted August 31, 2009 Report Posted August 31, 2009 i just did mine. i used a 17mil socket and extention to do one side and a 19mil to do the other side.my bearings were completely destroyed with the exception of the outer housing and i had them out in 5 minutes using a good bfh Quote
bobdryerr Posted August 31, 2009 Author Report Posted August 31, 2009 i just did mine. i used a 17mil socket and extention to do one side and a 19mil to do the other side.my bearings were completely destroyed with the exception of the outer housing and i had them out in 5 minutes using a good bfh K ill try that again but get a 2lb hammer ill let everyone know how it goes Quote
ISSUES Posted August 31, 2009 Report Posted August 31, 2009 Mine was so bad from the prev owner, the bearing was fused to the swing arm. I had to get a another one from a member on here. Quote
bobdryerr Posted September 1, 2009 Author Report Posted September 1, 2009 K I finally got them bugers out they where basically welded in. Took a 5lb hammer and a 19mil socket an beat the piss out of it but to find out my rear shcock is blown and I need new bushings in the bottom shock mounat an to the top part of that banana lookin thing. Quote
bbcmudtruck Posted September 1, 2009 Report Posted September 1, 2009 K I finally got them bugers out they where basically welded in. Took a 5lb hammer and a 19mil socket an beat the piss out of it but to find out my rear shcock is blown and I need new bushings in the bottom shock mounat an to the top part of that banana lookin thing. Haha, the bannana looking thing is your linkage and you can rebuild it with new bearings, or buy used one. As far as your shock goes, you can pony up for an aftermarket one or call Shane and have him rebuild yours for about $100. Bearing kit: http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=banshee+linkage+bearings&_sacat=See-All-Categories Shane at wolfpack racing: (219) 313-1424 Quote
lazzonya Posted September 1, 2009 Report Posted September 1, 2009 just did mine for the 1st time.... dremel with small grinding stone. carefully grind the needle bearing housing in a straight line (in and out of the swingarm) until it cuts through. once the housing is split a bit, it will pry out with a screwdriver. careful not to grind too deep and mess up your swingarm! Quote
