ISSUES
About ISSUES
  • Birthday 01/29/1983
Contact Methods
  • Website URL
    http://
  • ICQ
    Warrenton, MO
ISSUES's Achievements
  1. Works for me.
  2. http://bansheehq.com/forums/index.php?showtopic=126900
  3. Here is the link on how to remove the gold finish that chevybanshee91 was talking about. http://bansheehq.com/forums/index.php?showtopic=121759&hl= remove wheels&st=0
  4. Yea building and wiring it was easy "aleast for me" the hard part is the configuring and tuning and all that. Yes is am using a HEI module with a GM DIS coil for now, it helps keeping any voltage spike from the coil away from MS. Plan on changing it to like yours or going with EDIS 4 module with the 36-1 and COP to get better signal resolution and more updated engine speed then what I get now. Yes that answers fabrication side of things and setting for it which is better then get a msq file.Thanks Evan
  5. No I don't want to cheat to get out of the work, I have been playing with MS for year and a half and have my 95 corsica with 3500v6 running MS2 with the extra code and my shee but i used the stock pick up and flywheel to send the signal. Was just wondering about the setting for the 36-1. Sorry the previous post sounded like I just wanted to steal, I just like to see what others do.
  6. Awesome buildand the shee sound great , very nice job planning it out and laying it out to look like a professional job. Would you mind sharing your msq and tune files? Email me at [email protected] thanks
  7. Plan on use a walbro 255 fuel pump and megasqurit 2, as it is cheaper and I've built one before. No it will not hurt anything if you don't run a o2 sensor, just set the EGO step size to 0%. With MS the o2 only provides feedback for EGO correction. Most people running MS in their cars do not run o2 sensor, but they run wideband O2 sensor to a gauge not to the MS. As for different elevations MS 2 has a built in MAP for that, as for temps run a IAT and a temp sensor if you want.
  8. When I plan on doing mine next year, I don’t plan on putting a o2 sensor. It's not needed for something like this, putting one in won't last so no point. When doing mine I will enter the values in to the fuel table, adjust as needed after doing plug chops. But that is what I’ll be doing, to each their own.
  9. I believe this is the one your talking about, http://bansheehq.com/forums/index.php?showtopic=126900
  10. On the plug wires no it don't matter, the orange goes toward the front of the bike, black toward the back.
  11. Fast has them, Give them a call.
  12. 2x that. Aleast she had a Christmas she won't forget .
  13. I would of done the some thing, screw that stupid B$%@h.
  14. Will i'm 310lbs 6'4", You can also count me as pretty athletic fat.
  15. Ya it's a real fine texture like 120grit sand paper,really tough against scratches. The side cover I made my self from the stocker and some polycarbonate. Cheap and easy to do.
