banshee21 Posted July 21, 2009 Report Posted July 21, 2009 I am sure this has been asked about 100 times but i never have much luck with the search results. I have tried aircraft remover and it is taking it off but barely. Quote
SAVAGE420 Posted July 21, 2009 Report Posted July 21, 2009 I am sure this has been asked about 100 times but i never have much luck with the search results. I have tried aircraft remover and it is taking it off but barely. SOS pads. Quote
locogato11283 Posted July 21, 2009 Report Posted July 21, 2009 4" angle grinder.. juuuuust kidding.. :biggrin: Quote
LiftdT4R Posted July 21, 2009 Report Posted July 21, 2009 If you have a dremel or angle grinder the wire wheel for those works pretty good as well. Quote
LS1Inferno Posted July 21, 2009 Report Posted July 21, 2009 Quit complaining and put the motor back together :thumbsup: they make these little wire wheel type things that are like plastic with abrasive in them they have. http://base.google.com/base/a/4619337/D18223179295263528865 I use these to clean up cylinder heads and clean head gasket material off of alum blocks and the heads they work good and dont eat the aluminum unless you work it too hard/long I got mine for like 10 bucks so dont buy that kit Quote
moneybags Posted July 21, 2009 Report Posted July 21, 2009 What kinda of premix are you running and how much? Maby try some break cleaner. Quote
SheeBang92 Posted July 22, 2009 Report Posted July 22, 2009 get a peice of steel wool it wont take more than twenty minutes to get the carbon off both pistons Quote
ToomeySheeLE Posted July 22, 2009 Report Posted July 22, 2009 What kinda of premix are you running and how much? Maby try some break cleaner. Agreed .. must be running awful rich if the carbon build up is a problem.. if you can still read the numbers on the top of the piston I wouldn't get too excited about cleaning them up.. perhaps go down a main jet size though.. Quote
TurboBanshee420 Posted July 22, 2009 Report Posted July 22, 2009 do not use a wire wheel!!! you will imbed steel shavings in the piston crown only to be released later by piston wash and score the walls after it works its way into the the skirt. as said above...don't worry about that shit, It will only return after a tank of fuel. Drop a jet size and re-tune. If it runs good then you should only have about a fingernail sized clean spot next to each transfer port. The rest SHOULD be black with carbon...its NORMAL Quote
banshee21 Posted July 22, 2009 Author Report Posted July 22, 2009 I run 40:1 Klotz super techniplate. I couldnt read the numbers on the top of the pistons, I do need to bump down a couple sizes on the main. Quote
