Woody 350 Posted January 22, 2009 Report Share Posted January 22, 2009 What is the point of intake spacers? What do they do? What are the benefits/pitfalls? Thanks Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted January 22, 2009 Report Share Posted January 22, 2009 Generally, they are used to keep bigger carburetors away from the clutch arm. Some will say they increase bottom end, but I wouldn't use the spacers based on that claim alone... Quote Link to comment Share on other sites More sharing options...
04sand4 Posted January 22, 2009 Report Share Posted January 22, 2009 i was told that if you use a spacer it atomizes the fuel for performence . and the next time i was told that they do nothing at all. Quote Link to comment Share on other sites More sharing options...
12mm Posted January 22, 2009 Report Share Posted January 22, 2009 what would they do if you use them on stock carbs ? Quote Link to comment Share on other sites More sharing options...
njbanshee Posted January 22, 2009 Report Share Posted January 22, 2009 Some say you lose power because the carb is now further away. Waste of money. I bought them when i was a noob, now they sit in a box of old banshee parts. Quote Link to comment Share on other sites More sharing options...
12mm Posted January 22, 2009 Report Share Posted January 22, 2009 what would they do if you use them on stock carbs ? The bike i have them on with the stock carb runs good at half throttle but sputters at full,could not find the cause of the sputter but now im thinking maybe it's those spacer. Quote Link to comment Share on other sites More sharing options...
Woody 350 Posted January 22, 2009 Author Report Share Posted January 22, 2009 Some say you lose power because the carb is now further away. Waste of money. I bought them when i was a noob, now they sit in a box of old banshee parts. I'm glad I ask these questions, even though I'm sure they have been asked many times before. I am new to the Banshee and 2 stroke quads, i have a couple 4 strokes. It seems there are a lot of "cool looking" parts out there that are only good in making your money go faster. Thanks for the input Quote Link to comment Share on other sites More sharing options...
Dinner Posted January 22, 2009 Report Share Posted January 22, 2009 i was told that if you use a spacer it atomizes the fuel for performence . and the next time i was told that they do nothing at all. Hmm, I don't think the amount of increased volume (which isn't too much) would help atomize fuel anymore than it already is. The spacers are just a hollow block to do exactly that, space the carbs away from the Clutch Arm. The intake ports on the cylinders atomize fuel good, as long as they are kept rough :geek: Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted January 22, 2009 Report Share Posted January 22, 2009 You have to think about it like a high rise manifold off of a V8. the longer runners help at higher rpm and suck down low to change tq and hp curves. But those have valves to keep the fuel and air mix in the chamber. on a 2stroke. you have the reed valves. I could see it helping to flow more around more of the reeds rather then the round intake of the carb being closer to the cage. but that small of a spacer would be min if any none to gain on a small cc motor. Plus you have more worries about an air leak from more places. so buy two sets and let me know how they work!!! But the only real way would be to have your hands on a dyno to find out if spacing the carb farther away from the reed cage could help at all. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted January 22, 2009 Report Share Posted January 22, 2009 imo, you would want to keep the volume of the crank/porting as small as possible to keep it from absorbing the pressure of the pistons' downstroke, as well as feeding the low of the pistons' upstroke limiting the full flow of the reeds' open cycle. i think it would also increase delay time of the recipricating impulses at high speeds. spacing the carbs from the reeds may have a more positive effect though Quote Link to comment Share on other sites More sharing options...
official_style Posted January 22, 2009 Report Share Posted January 22, 2009 well my 97 came with them on, (and a fuckin boost bottle) so i want them off now. they are probably the same as the ones for cars and trucks that dont do shit. so anyways, when these things are installed, do they come with longer screws? like am i going to have to buy new stock screws to get these things off? Quote Link to comment Share on other sites More sharing options...
boneyardbanshee. Posted January 22, 2009 Report Share Posted January 22, 2009 yep they come with longer screws. why not just trim the ones you have? put a nut on them ,cut, screw the nut off to fix the threads. Buy another bottle of pre mix with the money you saved. Quote Link to comment Share on other sites More sharing options...
deckheight Posted January 22, 2009 Report Share Posted January 22, 2009 They do several things. Spacers set the reeds back farther from all the crank case turbulance which is mandatory in certain "case reed" applications. But not on Banshees which are "cylinder reeds". They also increase crankcase volume thus reducing crank case compression ratios which may or may not be helpfull depending... Pretty much useless on a Banshee IMHO. Quote Link to comment Share on other sites More sharing options...
jimbob Posted January 22, 2009 Report Share Posted January 22, 2009 i heard that on stock barrels and reed blocks the help to unmask the boost ports more. and that the fuel has more time to speed up and atomize better, THEORETICALLY but theoretically boost bottles are GRRRRRRREAT. LOL Quote Link to comment Share on other sites More sharing options...
