soo someone send me there stock screws, and ill send you the intake spacers and longer screws! great deal!!
Ace is the place!!!
But i could see that spacing out the carb from the reeds might help at higher RPM and will also help out F/M. but the 3/8 i believe the space is, is not enough to see any gains. but if you go back to a V8 carb. you can add diff sizes of carb spacers to change where your tq and hp curves hit. but it is little if any change. Thats why they make diff cams. as for the 2 stroke we have different porting. And if your spacers is on. Is it on the jug side or the carb side?
Ace is the place!!!
jugg side, but i can't see why not put it on the carb side if you need them. as for atomization, i like the idea of wishfully thinking more fuel atomizes as it hits the hot rotating assembly, leaving the oil there as it takes heat away.
i heard that on stock barrels and reed blocks the help to unmask the boost ports more. and that the fuel has more time to speed up and atomize better, THEORETICALLY but theoretically boost bottles are GRRRRRRREAT. LOL
Stock Cylinders do not have Boost Ports :ermm: ...or am I miss understanding your statement?
I'll take that deal, if you're serious.
Hell I'll even send you brand new screws.
In theory.. the longer intake tracts have better velocity..
You want to keep the reeds closest to the jugs. so the spacer needs to be on the carb side.
True and all but you also have to look at that each cylinder has its own carb on the banshee unless you have a 2-1. and the v8 has one or 2 4br carbs to feed that thing. so if anything i would see a better performance on the 2-1.
maybe.. maybe not. I personally feel that thet the gains from spacers are minimal if any. They should only be used to clear the clutch actuator... I was just stating the theory behind spacing the carb away from the reed cage.
When I used a spacer I put it between the carbs and reeds.
There was a guy awhile back that did some dyno work with spacers... but.. i'm not searchin for it.. lol
The bust or "boost" port is the single one on the intake side. Or maybe I'm not understanding either...
