12mm
Recent Profile Visitors
700 profile views
12mm's Achievements
  1. HERE IT IS
  2. you are right,it is a +12 deg timing plate that i have and it is run on only race gas. maybe thats why it falls on its face if you hole in the throttle to long..........when i got the plate it was suppose to be used on alc. BUT we could not get it to run on alc
  3. the guy i baught my timing plate from told me to +12 it i thought maybe that was too much but he said it was ok......it is on a 4mil stock cylinder motor with 18cc domes that run on Q16 VP fuel or 110. when i first got it,i was suppose to be running aly. but i could not get it to run good on it so i went back to gas but left the timing on +12,is this a safe timing for a 4mil/18ccdome motor on 110 fuel ??
  4. S O L D I have another set of cylinder and cases i may be selling soon......i'll post when i decide
  5. 64mm....they are ready to be used.......i don't have any pic right now
  6. I HAVE A SET OF STOCK CYLINDERS AND CASES FOR SALE $200 FOR EVERYTHING
  7. you should have it on friday or sat www.usps.com 03082690000068723514 tracking # thanks
  8. crank SOLD...........i have 4 cylinders and two sets of cases if anyone need some let me know.
  9. I HAVE A 10MM CRANK THAT NEEDS NEW BEARING ON THE BIG END I'LL TAKE $75 FOR IT IT'S A HOTROD CRANK TEXT ME IF YOU WANT IT @843-270-6151
  10. any pic's of the a modded shaft ?
  11. Does anyone have a pic of a MODDED shift star ? i have a spare one and wanted to try it out and see if it will allow me to shift better. if there are no pic then can someone tell me what needs to be done to it ?
  12. got a link ?
  13. im looking for a good set of cub cylinder......would like them ported if possible. i have a 4mil crank standard rod in the bottom end.
  14. will the cheetah need to be ported ? im running a stock cylinder ported for stockcrank and bore,so im hoping i can just botl on some cheetahs and gain some power.....theres also a 4mill under it now.
  15. is there any difference in the two power wise ?
