Titan up Posted September 20, 2008 Report Posted September 20, 2008 I've never popped the top yet on a 5 gallon steel pail of VP C-12 thats been sitting in my garage for about 6 months, enduring extreme phoenix heat btw. I don't know if I should go ahead and burn it in the banshee or just use it for Sobe bombs? :woot: Quote
blanco25 Posted September 20, 2008 Report Posted September 20, 2008 I wondering the same thing. How long till it goes bad? I heard your never supposed to leave it on the ground though. the people where i get my vp they always say keep it off he ground. also how long is it good if it has been opened? Quote
jbooker82 Posted September 20, 2008 Report Posted September 20, 2008 I fill my 55 gallon barrel and it usually takes a little under a year to burn. I dont notice any performance differences between the first fill up and the last fill up. I dont think race fuel breaks down near as fast because it is a better quality fuel. Quote
ban99 Posted September 20, 2008 Report Posted September 20, 2008 why would you use potentially bad gas on a good sobe bomb?? Just wrong. Put that crap in the wifes car. Quote
huskyohilux Posted September 20, 2008 Report Posted September 20, 2008 I guess fuel only goes bad if moisture get Quote
NYUK Posted September 20, 2008 Report Posted September 20, 2008 6 mos. c 12 i would use it. gas degrades faster in plastic containers. you will be fine.vp fuels aren`t chemical soup like pump gas. Quote
Tedder Posted September 20, 2008 Report Posted September 20, 2008 Since it was never opened it will be as fresh as it was 6mo ago. It's true that you should never store fuel in plastic containers or leave your cans on the ground or in the sun. If your running oxygenated fuels be especially careful how it's stored because the "good stuff" evaporates out first (and fast). Quote
Snopczynski Posted September 20, 2008 Report Posted September 20, 2008 Use it in the quad, dont put it in any car with a catalytic converter. Quote
RollinRhino Posted September 20, 2008 Report Posted September 20, 2008 As long as it hasn't been opened it should be fine. The metal can the gas comes in can condensate under changing temps, but a little dry gas would fix that as an insurance policy. You should be okay using it. Quote
