locogato11283
Admin
Everything posted by locogato11283
  1. Where are you located?
  2. Have it ported. Where did you buy the parts?
  3. Today is the day.
  4. Are these cylinders done?
  5. Uni foam filters? Anyone have a set of KN you can try? I never cared for the Uni. They hold too much moisture, dirt and dust. I'm betting the elevation and those filters are your problem.
  6. Just get it from Cam then.
  7. Ask for a time frame for completion.
  8. Like I said… came for info/advice. Listening to absolutely zero of it.
  9. It doesn't even make sense to build a 7mm. 10mm crank is the same money and takes the same work to build it. Your builder should have told you that. A 10mm Serval ported by someone that has built many of them is a much better idea. You'll only gain power off idle and you'll also gain power on top. CPI or Sniper will work well with a set of 35mm PWK. Those Smart Carbs are junk. I'd be calling Redline for this motor. Cam has built a ton of these.
  10. I don’t know why you’re still here asking questions. You asked. We’re telling you. You don’t seem open to the idea that you’re wrong.
  11. The whole thing. It's not going to run very well and you're going to be way down on power.
  12. You’re going to be disappointed but I don’t think you really want the advice.
  13. Pretty good chance that Raptor is going to eat you for lunch unless you get good traction off the start. You're really giving up a lot with this setup. I'd have it ported and it will make 10-15HP more. I'd run 35mm PWK over Smart Carbs. And I'd run Snipers. That combo should get you in the 115HP range.
  14. I'm guessing 95-100. You're missing out on about 10HP by not porting it. Single or dual carbs?
  15. A 4mm Serval on race gas will make around 100. I'm guessing the 7mm will make 5-10 more. 35PWK and Snipers or Shearers.
  16. Who's building the motor?
  17. 2026 BansheeHQ Spring Ride March 19-22, 2026 Little Sahara, OK We're doing this in conjunction with Duneman's Spring Break Dune Bash.
  18. Pick up the phone and call Cameron. He can build any size you want.
  19. Call Redline Racing. Cam has some very hard running Super Cubs. I had a 4mm 77 bore that was very strong. I won a lot of shit with that motor. He can set you up.
  20. Here’s some from the group.
  21. There’s a bunch of guys in the BansheeHQ Facebook group with them. Zero issues.
  22. Make sure you buy parts from our BansheeHQ Sponsors. There are a lot of scammers out there. BansheeHQ Sponsor Link
  23. I only started doing it because I was chasing a problem. It ended up being something electrical.
  24. I ran ground from motor to chassis but technically it doesn’t need it.
