wayne_smith97
    6
Everything posted by wayne_smith97
  1. Main is probably fine but I would definitely go up on pilot
  2. Will try this afternoon
  3. Yeah pickup gap is about .017 and plug caps I'm not sure about so I will pick up a new set. I do know the coil came off a running bike
  4. I'm having a similar issue. I am going to check my orange wire tomorrow. We might be fighting the same battle as I have continuity also just no fire. Three cdi's two coils and a stator and flywheel.
  5. Have you checked continuity in the orange wire across the harness
  6. Sitting in the shop. Some help here please!
  7. I have bought three CDI boxes. Put them on my banshee and they are not allowing it to fire. Took them to a buddy of mine and they don't fire on his either. Is there something in my wiring that could be frying them? I have a new stator and pickup coil. Also a new ignition coil. Key switch and kill switch test good. I also have checked harness for continuity and all looks good. Any thoughts????
  8. Bought a spring and o ring kit from him. Got it two days later. Would definitely buy from again.
  9. Whiskey Throttle
  10. I believe 24 is
  11. Air leaks can lean out your fuel mixture and burn up your engine.
  12. Pressurize the coolant system and see if you can spot any leaks. While pressurized pull the plugs and look down in the cylinders and see if anything is accumulating.
  13. 1.5 turns out and bout 60 degrees
  14. I will trade mine right now for an F250.
  15. http://northmiss.craigslist.org/sno/4370831245.html
  16. http://miami.craigslist.org/mdc/sno/4335715937.html Is this even possible?
  17. If JD made it's good stuff. No question
  18. I had this happen (not on a banshee) and the float needle was stuck and pouring fuel into the crank case. A new needle and seat then BOOM problem solved.
  19. I'm at 400-800ft and have the exact same setup from fatties to the pods and run 300/290 mains and a 27.5 pilot
  20. I have a nice stock airbox with pro flo adapter and foam filter with boots and clamps. Will not be home til tomorrow night. I will get pics and send them to you. Pm me your number
