wayne_smith97
    6
Everything posted by wayne_smith97
  1. The choke plunger o ring. It will unscrew with wrench from the left carb.
  2. ^^^^ this. Keep in mind that easily obtainable parts means more competitive pricing and I'm all for fair prices!
  3. I would help out too. My cylinders are just about ready for a bore. So time for a new top end anyways.
  4. Buck tell me if pics come thru. I am having the hardest damn time texting you. I have to send a message and then it rejects it and then have to resend it as a text message. Stupid I phones
  5. Get a compression tester. First pull the plug caps and trim 1/4 in off and reinstall
  6. I responded but it didn't send for some reason just resent it. Let me know if you don't get it
  7. You get some more pipes and price me your FMf silencers. Did you post that ad too? I didn't see it
  8. That missing choke tube is part of your problem. Replace it and try again. Clean your carbs and install that tube and try to run it
  9. I wouldn't be either
  10. Text me 731-431-3378
  11. Yes I have seen the bunzle oof pipes on CL. I will try to find the posting Found this posting. http://inlandempire.craigslist.org/sno/4392684643.html
  12. I might try to find me some new silencers and stingers
  13. I've got everything minus the slides
  14. They say FMf on them but don't know if they are old powercore or etc
  15. Can anyone tell me what silencers are these? I have these and there are no markings but FMf and spark arrested. Sent from my iPhone using Tapatalk
  16. Check the choke tube
  17. Then I would file a claim with paypal.
  18. Did you send money as a gift?
  19. I tell you what. You said it will start if you put fuel in the cylinder. Get it started, choke it(full choke)and see if the fuel flows between the carbs. Try this first
  20. I would say that there is a clogged up passage on the choke circuit. Loosen the screws on the carb bowls and make sure (again) that fuel will flow out of the bowls. If it does then that left carb is still dirty
  21. It won't be a lot but when you kick it with the choke on it will kinda mist thru. Look real close. Kick it ten ten times with the choke on then remove tube and see if there is evidence of fuel
  22. When you kick it you should see fuel going from carb to carb in the choke tube if the hose is clear. Check that out.
  23. Mrdjc where are you from?
