sugarshack81
About sugarshack81
  • Birthday 04/30/1981
    South Texas
    1998 Yamaha banshee with FMF SST
sugarshack81's Achievements
  1. My banshee finally started. I built a new harness and it works great. When I get time I'm going to post everything I did and how I made the new harness. I learned a lot and hopefully I can help someone else out. I appreciate everyone that commented and gave me suggestions. So I'll post later, Right now I'm putting everything back together so I can go ride today.
  2. My banshee finally started. I built a new harness and it works great. When I get time I'm going to post everything I did and how I made the new harness. I learned a lot and hopefully I can help someone else out. I appreciate everyone that commented and gave me suggestions. So I'll post later, Right now I'm putting everything back together so I can go ride today.
  3. My banshee finally started. I built a new harness and it works great. When I get time I'm going to post everything I did and how I made the new harness. I learned a lot and hopefully I can help someone else out. I appreciate everyone that commented and gave me suggestions. So I'll post later, Right now I'm putting everything back together so I can go ride today.
  4. My banshee finally started. I built a new harness and it works great. When I get time I'm going to post everything I did and how I made the new harness. I learned a lot and hopefully I can help someone else out. I appreciate everyone that commented and gave me suggestions. So I'll post later, Right now I'm putting everything back together so I can go ride today.
  5. My banshee finally started. I built a new harness and it works great. When I get time I'm going to post everything I did and how I made the new harness. I learned a lot and hopefully I can help someone else out. I appreciate everyone that commented and gave me suggestions. So I'll post later, Right now I'm putting everything back together so I can go ride today.
  6. I bought some ngk plugs for my banshee and they tested at 16000ohms. Wayne you should check how much voltage you have from your stator. Use a multimeter to test voltage on green wire coming from your stator. I doubt your frying your cdi somehow. Did your friend let you try his cdi on your bike. I hope you get it fixed I'm in the same boat im just not getting spark to transfer to my ignition coil. My cdi does give out a signal on the orange wire just not when the harness is connected. Good luck I will let you know if I get my bike running and what i did, do the same for me if you get yours going. Sent from my SAMSUNG-SGH-I747 using Tapatalk
  7. Still not getting spark. Using a cheap test light. Lights up on orange wire from cdi when I kick it over and when the harness is connected it doesn't light up on the orange wire. Tried jumping terminals on the kill a key switch and still no luck.
  8. I'm thinking kill switch or key switch one is causing this. Which I've read other posts saying they went through hell trying to get spark at it ended up being kill switch. Actually I hope that's the problem just want to get this thing running. Sent from my SAMSUNG-SGH-I747 using Tapatalk
  9. Correct me if I'm wrong but can I connect the black/red wire from cdi to ground wire and the black/white to new on/off switch then ground the switch, connect black ground wire to - on coil and orange wire to + on coil. Should get spark? Just hate to cut all wires coming out of the cdi if this won't work. Sent from my SAMSUNG-SGH-I747 using Tapatalk
  10. Yes have continuity. Sent from my SAMSUNG-SGH-I747 using Tapatalk
  11. No. That's why I tried a new wire. Its weird I get power right out of the cdi just not while the harness is hooked up Sent from my SAMSUNG-SGH-I747 using Tapatalk
  12. Here is a picture I drew to see if anyone can help me figure this out. When I disconnect from my harness and run a test light on the orange wire coming from the cdi I get voltage because it light up. When I connect the harness I loose voltage on the orange wire. So here is what I tried. I bypassed the orange wire on the harness and hooked it directly up. The rest of the harness is hooked up normally. I added extra ground from coil to motor and still not getting spark. But as soon as i unhook the harness the test light will light up again on the orange wire. This really sucks. Feel like I'm getting close. I tried a second wiring harness before attempting this. Its like the where the harness connects to the output of the cdi it shorts it out maybe?
  13. Here is a picture I drew to see if anyone can help me figure this out. When I disconnect from my harness and run a test light on the orange wire coming from the cdi I get voltage because it light up. When I connect the harness I loose voltage on the orange wire. So here is what I tried. I bypassed the orange wire on the harness and hooked it directly up. The rest of the harness is hooked up normally. I added extra ground from coil to motor and still not getting spark. But as soon as i unhook the harness the test light will light up again on the orange wire. This really sucks. Feel like I'm getting close. I tried a second wiring harness before attempting this. Its like the where the harness connects to the output of the cdi it shorts it out maybe?
