wayne_smith97
    6
Everything posted by wayne_smith97
  1. I approve this. Ragin, most tunes are worthless in gas engines, but Blackbears. Only has tune I've seen that make you go "oh hell" when the tow haul button tune is used.
  2. Correct. He makes rounds around the country every year.
  3. Same here. I have a couple of hypertech boxes on the shelf. Then I got my first Justin tuned pcm out of a wrecked truck. I was stunned.
  4. You won't regret it. Blackbear is top notch.
  5. If you have a tow haul button on your shifter, he can put a mild fuel saving tune in. Then when you hit the tow haul buttons it brings up a wild tune.
  6. I've had two pcm's that he has done. Night and day. Ask about the tow haul button tune as well
  7. Justin is the shiznit. He knows how shit.
  8. Carbs, pipes and air filter setup.
  9. http://bansheehq.com/forums/index.php?/topic/110585-leakdown-tester/page-6#entry1781595 Read up on this. This a good how to on the leak down test.
  10. Where are you from?
  11. We need to know what type of pipes, air filter setup and if it passes a leak down test. If the bike had been sitting up then I would def do a leak down to make sure the seals haven't gotten brittle and started leaking.
  12. Need a little more info on your setup before anyone can give a jetting suggestion. The number on the side of the pilot jet is the size. 25 is stock. Jets don't really go bad unless so what's screwed up the passage or tried to drill them unsuccessfully. Vforce fit the banshee. Make sure they aren't cracked and that they are closing right.
  13. In order for the builder to make it right, he has to be contacted. Tdodd, see if he does.
  14. Really need to know compression
  15. I think I remember the builder of that motor. If it is who I think it is, contact them before putting them on blast. That builder has been good to me and a lot of others.
  16. I would even be satisfied with standard mail. It's the ppl that sit on the part or order for two weeks before shippping that's gets on my nerves.
  17. No these are actually welded
  18. They pretty much told my dad if he ever got to speak again, that he would sound like farmer Fran!
  19. What kind of plug is that?
  20. Banshee. Nothing wrong with an r, but in my experience banshee parts are far easier to get.
