tdod101
Banned
    2
Everything posted by tdod101
  1. Oh and by the way chances are your gaskets will get all fcked up so you'll have to get new ones unless your getting new reeds
  2. I had the same problem stick a small - medium size flat head screw driver between the Reed and manifold and lightly tap it with a.hammer, do all 4 sides. It won't take much once your crack the seal. Don't be afraid to hit it
  3. I just got vforce 4 reeds from fast $195
  4. 140 seems extremely low. I'd go 290 at least with 30 pilots
  5. This: http://bansheehq.com/forums/index.php?showtopic=140912
  6. Thank you, somebody on everything2stroke was saying the same thing, they recommended this: Main Jet: 290 - 310 Pilot Jet: 27.5p Needle: middle clip Air Screw: 1 1/2 turns out
  7. Gonna order a manual online, which one is better ?
  8. Yea I figured as much, try just look smaller is all, my sled carbs are 36mm mikuni
  9. So I'll be getting a 27.5 pilot jet, I've just read that it has to be banshee specific, true ? So it won't be the same kind of pilot in my sled ?
  10. Well that gives me more confidence to run amsoil in my 583 skidoo and my banshee. Good!
  11. Sometimes these machines are well built, and some times you get one that was made on a Friday, always keep that in mind
  12. I do have a drill press at work. I'm thinking that might help drill a straight hole
  13. My kit is on it's way along with a bunch of other cool goodies, in pretty stoked too! Ill be getting a machine shop to do it though as I don't trust my drill and tapping skills
  14. Ill be using interceptor at a 40:1 ratio with premium gas. Sounds good to ne
  15. Vforce 4 reeds fmf silencers an pipes, twin k&n air filter pods direct to carbs. Elevation 800 - 1000 ft
  16. Ok but will they work for my needs is the big question
  17. Ok great! Thanks for the input, I've been looking at the 6 ply max is razor tires, they look bad ass
  18. Alright I will, but what kind of tire do you recommend ?
  19. Looking to get rear tires, I ride everything, mud, dirt, sand, snow. What's the best all around tire I can get and who would have the best price ?
  20. Normally I would keep my opinion to my self BUT those look pretty dumb, keep your stock head lights
  21. I've been reading up on advancing the timing to +4 which is what most people seem to do, obviously I'm better off getting a timing plate to make it easier, but I can't really find any info on how to do it with out buying a part.whats involved is what I'm asking
  22. Vm is the round slide correct ?
  23. I'm sure most of you know by now the mods I have or will be installing shortly, I'm starting with 300 main needle in middle and 27.5 pilot, what do you reckon my air screw should be ? 1 turn out ? 1.5 out ?
