yzrmbsg
Everything posted by yzrmbsg
  1. Weld on some mounting tabs to your frame, subframe should already have the tabs, unless its a weld-on subframe
  2. I can't see the after pics!
  3. Thats not bad at all! Ive had a 99 since new, bought in 98. Stock bore, crank, cylinders, only rebuilt it once in 2001 with wiseco pistons, didn't even need it. Still runs like a raped ape today! I'm gonna go 4mil this winter though! Congrats on the great trade!
  4. Rims spinning inside tires.....
  5. yzrmbsg
    paddles
    Pm sent
  6. Ypu have a pic of the paddles mounted?
  7. ^ those look badass! Nice job!
  8. yzrmbsg
    St A'S
    Lucky bitch! Is it just you and Matt going? I wish I was going with you guys again! No money, or time off after the last trip. Hopefully your guy's bikes will be running better this trip! You ever get your jetting dialed in?
  9. Ill take the blaster arms off ya if you dont want them?
  10. Shucks/checker/o'reilly's
  11. I went with black pc. No maintenance! Same bike, different plastic.
  12. Simple answer....YES!
  13. Take some #00000 steel wool to them, you'll be amazed at the difference it makes.
  14. #00000 steel wool to take the grime and rust off, then some polish and a wheel, shines them right up! Requires a bit of elbow grease!
  15. Thats what I mean, the cable tightens up and/or gets sticky when not being ridden, then once started, it vibrates/heats up and moves back to where it should be. Lick DEEZ NUTZ!
  16. Maybe a sticky throttle cable?
  17. Pm sent! I love free stickers! Lick DEEZ NUTZ!
  18. Just looks like a fat bar with a high bend and the cross bar removed. It's only 2 bolts on the cross bar mounts and they slide right off. I like the look of bars without the cross bar, I took mine off, people say it makes them weaker though. I haven't had any issues. I don't do a lot of jumping or smashing my helmet into the bars though, so I'm not to worried about it. Lick DEEZ NUTZ!
  19. I'll test one out for ya! Sent from my PC36100 using Tapatalk 2
  20. Gliders? Haulers? Extremes? Rippers? Lick DEEZ NUTZ
  21. If its not grounded, it wont run at all. Sent from my PC36100 using Tapatalk 2
  22. Yup, be sure to scrape off where your regulator mounts to the frame and the ground off the cdi box, the rest connect to it, so you should be good from there. Sent from my PC36100 using Tapatalk 2
  23. I have some 20/10/10 8 paddle extremes with pc'd black wheels.... I would love to trade!!! Or buy yours! Sent from my PC36100 using Tapatalk 2
