706DSGB
    Copperas Cove, TX
    1990 Yamaha Banshee(BLUE) Mods: 2 into 1 Stage 4 Trinity Carb Setup 35mm Carb Bored and Ported .40 over FMF Full exhaust K&N Air Filter Tusk Nurf Bars Ricky Stator Ricky Stator CDI Box Twist Throttle(Bout to Switch over to thumb throttle)
706DSGB's Achievements
  1. Went out today and checked everything out that y'all suggested and my tires just spend alot. My tires have like 85% thread. So should I try different brand tires or what.
  2. I do have +1.5 in the rear +2 was to wide for the trails I ride. I going to check today and see if the rims are spinning. What are some good tires for the rear in this situation. Tires that have great traction. I currently have (Razor 20x11-10) in the rear. Thanks for everyone suggestions im going to check all these things right now
  3. I just rejetted it casue it was to rich and it was bogging a little. It does spin but I have good tires on it I have Razar 20 x 11 in the rear. They have good traction I dont see that being the problem but it could. If so how can I solve this problem 1990 Yamaha Banshee Trinity 2 into 1 Setup w/ 35mm Carb FMF Fatty Exhaust System K&N Air Filter w/no lid Wiseco Pistons Bored .40 over Rick Stator stator w/ adjustable timing(+4)
  4. I have notice that when I'm in low gears my banshee dont seem like it pulling like it suppose to. I cant even get the front tires off the ground. Im in the powerband but once i hit the high gears it really pulls and you can tell a big difference. 1, 2, and 3 it dont pull right at all but 4 and 5 hold on cause here I come. Also at high rpm it is hard to get it into second gear sometime impossible unless I literally kick the shit out of it into second. Any help would be appreciated. Thank you 1990 Yamaha Banshee Trinity 2 into 1 Setup w/ 35mm Carb FMF Fatty Exhaust System K&N Air Filter w/no lid Wiseco Pistons Bored .40 over Rick Stator stator w/ adjustable timing(+4)
  5. I need a little advise here. I want to widen my banshee a little to make it more stable but not to wide for the trails. What size wheel spacers should I go with. It is sitting at the stock width right now which is like 43". I was thinking +5
  6. I need a little advise here. I want to widen my banshee a little to make it more stable but not to wide for the trails. What size wheel spacers should I go with. It is sitting at the stock width right now which is like 43".
  7. I need a little advise here. I want to widen my banshee a little to make it more stable but not to wide for the trails. What size wheel spacers should I go with. It is sitting at the stock width right now which is like 43".
  8. My banshee wasnt getting spark at fist so I ordered a stator, ignition coil and a CDI box from Ricky Stator and still no spark. So I put all my old parts back on accept the ignition box cause my old has a broken cap. So now I got spark but I want still start up. It has compression, gas, and I even got the right cap between the flywheel and coil. I also tried pulling it with the truck as well.
