yzrmbsg
Everything posted by yzrmbsg
  1. Big Nasty Hillclimb in New Plymouth, Id Sent using Tapatalk!
  2. One to ground and one to the black with white stripe wire, you want the mount part of the assembly to be wired to the ground, and the "plunger" connected to the black with white stripe wire. Sent using Tapatalk!
  3. Why dont you just do a google image search? Much easier than waiting for people to post on here... Sent using Tapatalk!
  4. Check to see that your throttle cable isn't bound up at all and then when you start it it vibrates back to the position it needs to be, wouldnt hurt to lube it up with some wd-40. That or you may have a small air leak. Check your crossover tube and carb boots for any cracks. Sent using Tapatalk!
  5. If all your connections are good, id consider getting a new cdi box... They do go bad on occasion. Sent using Tapatalk!
  6. I don't remember who posted it, and the search isn't showing up shit, can't find it. Maybe whoever posted it will see this thread... Sent using Tapatalk!
  7. Thats the same one from the cl ad the other day! Sent using Tapatalk!
  8. Wooohoooo cant wait! Leaving early thursday morning! Sent using Tapatalk!
  9. That guy is definately retodded, smoke him. Sent using Tapatalk!
  10. Looks great! Sent using Tapatalk!
  11. A custom Vegasjeff seat cover! Sent using Tapatalk!
  12. You can still buy those new if you didn't know. Sent using Tapatalk!
  13. He says no scratches, great condition blah blah blah, the shock seals are blown and the bump stops are trashed, the tierods need new ball joints, the arms are scratched to hell, and the heim joints are as loose as a 50 cent hooker. He sent them all dirty and greasy as fuck too.Do not pay $400 for this shitty ass "deal", oh and on top of all that, they took over a month to recieve because he kept saying he'd send it this day, and then that day, and then this day, then he just disappeared and wouldnt reply to my calls/texts/pm's/emails. So I filed an item not recieved dispute with paypal, and the box full of shit showed up 3 days later. Good luck to the next buyer! I'm glad I didn't send my money paypal "gift" like he wanted me too. The worst part was paying $58 to send them back to him, what a waste of time and money. Sent using Tapatalk!
  14. Yeah, it took a while to get out there, if I ever go oit there again, I will be taking the freeway to payette, not taking the backroads thru emmett. There is not much out there for sand, theres 2 half bowls, 2 decent straight open areas to race/open her up, and a couple of rocky/sandy hills, and a few small sandy trails. We rode for about an hour or so and were bored with it. I'd say maybe about 300yds long by about 100yds wide. Not worth the drive to actually go ride there, but it's definately a good spot to test and make sure everything is working properly, I'll probably go out there to test/break in my new motor next year, but thats about all it's good for. Sent using Tapatalk!
  15. Thanks! Next winter I will hopefully doing a 4mil build. Maybe I'll have a second Shee by then! It was definately a blast building this one up from the frame to make it my own!
  16. Went out to the local Weiser "sand pit" today to test and make sure everything was working properly! Runs and Rides great! I can't wait to be in St Anthony's next week!
  17. All cleaned up and out in the sun! I'm so happy with the way it turned out! I am finally done! Next winter will be motor building time!
  18. Make sure everything is hooked up correctly, this is the stock wiring schematic. Follow each wire to its proper place, and make sure you have good grounds... If you just powdercoated the frame... I know it sucks, but you may need to take a dremel and grind down to bare metal to make sure you have a solid ground. Sent using Tapatalk!
  19. Fuckin FINALLY DONE! Night shaded my rear tail light! I'll take some better pics of it outside in the sun tomorrow, just got done cleanin up the garage.... What a pain! I'm so happy with the way it turned out! It looks fuckin badass! Sent using Tapatalk!
  20. Yes, you can, here's the shematic for when you get to it, just solder/crimp the 2 wires together and you wont need the key. Sent using Tapatalk!
  21. Got my vegasjeff seatcover installed finally! Looks badass! Also chased down my lighting issue, didn't scrape of the powdercoating on the fram when I installed the voltage regulator so it wasn't grounded. Cut and painted the rear plastics... Hopefully I'll get her all finished up tomorrow or thursday! Sent using Tapatalk!
  22. Finally got my spider seat installed!!! Looks badass! Thank you! Sent using Tapatalk!
  23. Thank you! Do you have a build thread as well? Would love to see pics! Thank you! Post pics up! With the plasti-dip painting plasting, its a pretty easy process, all I did was clean with soap and water, make sure it was dry, and sprayed. They say a good layer of wax/polish is good too, but i figured thats more for painting metal, as the plastic was already pretty smooth with little scratches or wear at all really. Sent using Tapatalk!
  24. Buy the idle screws and save yourself the headache. Sent using Tapatalk!
  25. Limited Edition Sent using Tapatalk!
