Redline Racing
HQ Site Sponsor!
    4
Everything posted by Redline Racing
  1. If your going to keep stock bottom end I'd just port your stock cylinders and head mod. I wouldn't spend the money for a stock stroke serval. A good ported set of cylinders , head mod, timing plate and reeds will get you mid 60's easily. If you want to get a crank and other supporting parts then a serval will far surpass stock cylinders.
  2. I think there may have been issues with them.
  3. Give me a call got them instock!
  4. Ya I know I tore your mtr apart and your wang crank was broke. Feel sorry for sap that bought your mtr.
  5. Yes tape is sold separately. By the foot of course.
  6. billet stator cover and billet shifter. Stator cover needs polished but it's not horrible. Shifter is stock length. 85 shipped in US. Will not separate.
  7. I had millinium repair one like that has been 3 years. Send it in and tell them to give you estimate on it. If it's not repairable they will tell you.
  8. I will be more than happy to drive rental car.
  9. Customer is selling complete LSR axle. All hubs area aluminum and tight. Billet carrier, bearings seem real smooth. Would like 175 shipped.
  10. I would personally weld the gasket surface. We then fill pockets on deck with epoxy then surface tge deck. If it is over a 10 DM you will need to epoxy bottom case. If done correctly it will last pretty well. I have seen cases where they epoxy the deck. They seem to hold up ok but scares me cleaning gaskets off. Cam
  11. Thanks to BHQ it was a great year at the shop. So to say THANK YOU we will offer a few specials. All prices are shipped, you can pay with Pay Pal or call with a CC number. Thanks for all support. Cam Shop number 1-541-367-2453 Pro Mod tranny This will require us modding your tranny. Pro Mod 2-5 Roller drum Shift star mod Shift shaft mod Shift Pro kit 150.00 shipped ( you pay shipping to me) UPP banshee intake manifolds (black) 26-28 mm 33-35 mm 38-41 mm 80.00 shipped Chain & sprocket kit WPS gold o-ring chain 140 link 9000 lb chain works awesome on Banshees. Chain Front & Rear Sunstar sprockets All standard sizes 130.00 shipped REDLINE CLUTCH KIT OEM street bike frictions(7) Full circle steels(6) Your choice of springs(6) Clutch pancake bearing(1) 100.00 shipped REDLINE PANCAKE BEARING 20.00 shipped each Buy 5 get 1 free. 100.00 shipped Billet 8 plate clutch baskets Hard Annodized black chromoly backing plate 5/16" hardware not smaller 1/4" Cushion kit. 145.00 shipped Mattoon billet timing plate 45.00 shipped Shift Pro kits Lighter Detent spring Roller Detent arm Helps shifting under power ( not recommended for OR trannies) 58.00 shipped Thanks again for great year. All parts shipped USPS. Allow 2-3 days for tranny cutting. We cut yours not exchange them. Thanks Cam
  12. Results posted on Planetsand. He paid more.
  13. Two strokes are dying tge second you start them. No time for break in. Lol
  14. I got both new. 75 shipped. If interested pm me.
  15. Can Falicon do Yaris cranks?
  16. I've built quite a few of the 10 mm 75 mm small blocks. I'd run stock style cages unless you can get the older v2 cr125 cages. I'd get it without sleeves in it to grind transfer tunnels easier or have lew cut them. I like lew alot but he can be VERY difficult to get parts from sometime. I would do a 521 super cub. Start with a serval to get port timings where you want them. Spend the time on getting pipes setup for your RPM range and it will rip. I did one on gas with 41's and inframe sheares it was little pipey but pulled like crazy. I know with a couple simple changes it would be way better than a twister. You can also get the parts very easily. Cam
  17. I would assume your float bowls are on the wrong carb. To operate the choke it must have the float bowl with a cross drilled choke tube hole. Look at the front if each if your float bowls. One should have a small brass ball pressed in the front if it. This bowl needs to be on your left side or choke side carb.you can look while carbs are on bike. If this is correct your out of luck. Lol
  18. Phil you sent me a PO for that.
  19. A new DM top end is 2900. Ported and plated cyl Head and custom domes V force and billet intakes Flanges Studs and all hard ware. Pistons. Porting 350 Domes 125 Plating 200 You might save 225.00 at most.
  20. Back off timing to .080".
  21. Don't use haulers you'll want rippers. Make sure tge operator is wearing a helmet with a Go Pro.
  22. I keep my stack in a refrigerated room. My dyno or dyno's are stingy.
