Larry's Shee
    6
Everything posted by Larry's Shee
  1. You'll find sympathy in the dictionary somewhere between shit and syphilis. Pretty expensive tuning lesson.
  2. What's your time worth? Considering you can buy one for less than $20. It's great that you can make shit. And considering I've had to whack the center bolt, I'd only use steel.
  3. Dates? This AMA? Rules?
  4. Pssh, a race is a race
  5. Why do you want to change it?
  6. Start with swapping plug wires side to side. Have you done a leakdown test yet? If not, come back when you have. Float bowls on correct carb? They're different. Choke tube? Slides correct?
  7. Intake and exhaust "pieces" are what matters (mainly) If it were ported the seller would have mentioned that as a selling point. So, do you have two filters on the carbs, or one filter in a box? Does the box have a lid on it? If so, does the lid have a snorkle that goes up under the gas tank? Example of difference in jetting. What would work for summer, would need to be 3-4 sizes BIGGER in the winter. Always jet on the rich side.
  8. Detroit Diesel for the mutha fukin 2stroke screaming DEEEtroit win
  9. Find out if PO did a leakdown test, no matter you should do one yourself. List ALL of your mods (that you know of) size of jets in the carbs. I would highly suggest NOT riding until someone verifies you have the correct jetting. No, not normal to be shutting off after 7 minutes. Excess oil could be from leaky seal or carb sync or adjustment. Buy a Clymers Repair Manual. Least you didn't come here making 2 strokes or Banshees sound like some kind of fucking voodo majic
  10. Really hate to suggest him, but I thought Rattle Can Ray was selling new R2s? Pretty hard to fuck up new parts.
  11. You can go faster with good suspension, but have more fun with mo powwa porting, pipes, maybe VF4s
  12. Okay, I'll be reasonable. $550 on clues $550 on hookers and blow
  13. $1000 on clues $100 on hooker
  14. Ohm out all electricals, report back when done. Values are in the Clymers repair manual, or if you can find the pdf on here.
  15. IIRC, ground wire goes to reg/rectifier instead of grounding to stator plate. I've never done this so don't take this as Gospel truth. If I'm wrong someone will come along and flame the fuck out of me, which will be good.
  16. Also depends on temp. Thing with jetting is always start big/rich and work down. Plugs are cheaper than pistons.
  17. This ^^^ and checking the stator. Don't drop the flywheel.
  18. Don't know what "can tips" are, I used some pvc caps I glued in with 3Bond. Don't need no stinkin crossover. When you do test, that is one area to check for leaks.
  19. Also check the carb vent tubes>
  20. Weird, good news is that it runs right. Bad new is you need to find out why. I suggest draining tank, cleaning it and petcock, fuel tank cap vent, and carbs. Just think, this is all FREE !! Side note: that is about the going price for cdi in the states. You're in South Africa, correct?
  21. So sad, purchase without research. As to DC conversion, add regulator/rectifier and float the ground. Google is your friend.
  22. Google is your friend. Some say 6lbs for 6 minutes, 7 for 7. I use a Harbor Frieght cyl tester, couple plumbing pieces for the intake & ex. I need to "modify" the pvc cap I use for intake so I don't need to use spark plug hole. In doing the test if it won't hold air you test the tester for leaks, then move on to engine areas. By chance you don't have a boost bottle do you?
  23. Well usually a deficient spark rears it's head under load, not at idle. Seeing as a banshee uses a wasted spark, most one cyl misfires are either carb or pick-up related.
