Larry's Shee
    6
Everything posted by Larry's Shee
  1. To bad Yammy isn't smart enough. Should have dumped the j-arm and copied the 250r frame geometry. Wan't till the 450x/r that they have nearly same frame rake.
  2. nope. lots of other parts pieces that could be out of wack tho
  3. How long you been running the V12? Have you ohmed coil and plug caps seperate? Ohmd stator and pickup coil?
  4. Are those plugs from riding all day? Or from a single pull?
  5. This is for nowheels : http://lmgtfy.com/?q=How+to+plug+chop%2B+Banshee+HQ Now school this old fuck, what's wrong with pocket tees?
  6. Plug chop or "read" your way to perfection.
  7. Good question Darkblade hyjacks thread asking for jetting advice, then gives advice without enough info from mike, such as "what filter set-up Mike?"
  8. cylinders mismatched in some way, one pipe restricted (dent?) , oddity with one carb (bored?)
  9. IMHO, good reason to do a leakdown test. Go through every aspect of carbs, no matter how insignificant it may seem
  10. With "wasted spark" on a bangshee, it's hard to tell if the spark you see is TDC on the right or left cyl.
  11. http://lmgtfy.com/?q=How+to+exhaust+flames
  12. Tiajuana Tacos? + cheep beer?
  13. Goldstein, Goldburg, Goldblaum, & Fieger ...................... nuff said
  14. Carbs or air leak
  15. Previosly owned by low ridin', ghetto slamin' foo ?
  16. Only time it may suck air through ex is if it isn't sealed well between flange and pipe, reeds have nothing to do with it. Chipped, frayed, broken, not sealing (laying flat) are reed problems.
  17. Uhmmmmmmmmmmmmmm Have you done a leak test? Your dyno "guy" don't know shit, two different jet sizes, WTFIH?
  18. How many psi for how long? Go back through carbs. Check slide cap gaskets, reclean, make sure you can see through pilot, air blows through ALL passages, pull emulsion tube/main jet holder. Check bowl vents, float level , and condition of choke lever. With clear tube on bowl drain , hold by side of carb with end above gasket surface, crack drain open, you can see exactly what level is
  19. Yes, but he was out being flogged for rejecting to many parts. Ya, I hate when I don't leave myself with enough time in case something goes wrong. That's a mistake itself
  20. Wasn't supposed to be funny, didn't feel like fucking around looking for where to put it, this thread gets read more, someone might be looking for burble, so sue me
  21. Buy one, let us know if they finally got them to work correctly.
  22. Purple plastic : http://flint.craigslist.org/snw/5067202172.html
  23. to bad it needs a bore. Could make hella deal on some 64s someone stuck in 64.5 holes, No carbon on one piston, very little on other. Hey, what the fuck ya xpect for a $600 wonder.
  24. considering you are supposed to do an incremental pattern, what would you say? if someone says "Go ahead, it don't fucking matter" then you have the answer you're looking for.
  25. http://lmgtfy.com/?q=piece+of+fuck+%2B+Banshee+HQ
