SD1026
Everything posted by SD1026
  1. i need to get some action shots these are sick
  2. compression test and leak down then check the sync on the carbs. have you testes the plugs by swapping sides
  3. not feeling that at all too many coolant tubes
  4. looking to get a temp gauge so i can tell whats up and when i should shut down. looking for a good one nice and clean. i have no fenders sooo that leaves the radiator shroud i guess.
  5. wacko was telling me about this it looks sharp. joe i dont know why you didnt do this. is it posssible with any pipes.
  6. omg my man desperate measures huh????? u just needed degreaser scrub bush and a hour with a nice power washer.
  7. if he does post in here he will say the 450 blew up then it went on fire which made his house catch on fire. story after story.
  8. yea of course i would too but you know a 20.00 oring kit and a little labor and time can tell alot .
  9. just need the one dome 15 shipped????
  10. Nothing we can do but fix it. Kid lived 6hrs away. New crank new jugs and pistons re porting. That's all we can do. Funds were supposed to go to powder coat and clean up the bike. But all hq should learn from this. Meet in day light with no plastics on bike confirm the bore and everything. If people don't wanna tear it down a little to confirm don't buy it. Take the head off leak down test compression test. Cause thing like this make it very expensive and puts you in the hole before u even get use of a bike. I gave the bike a compression test and it was a dead 151 in both cylinders.
  11. i have stock airbox with proflow plate and 5 replacment k&n filters.80 shipped.
  12. can be your clutch. if you were haveing trouble shifting into the next gear i would sat get a shift star.
  13. i dont think thats normal.
  14. for performace across the board i would do a nice set of pc's. then a noss head.
  15. I couldn't agree more. There are just isn't a nice way to put this in words. So I will keep posting pics. The cases will be split tonight after the flywheel get cut off do to it being self welded on the crank basically.
  16. Person claims that he bought the .30 over pistons and installed them. Also said he would have never put the cylinders back on with out a cylinder skirt missing. So truth be told the bike is .100 over and a skirt is mia any other opinions where it could be. Me and the kid have been in contact and I'm honest about the condition of the bike and the disappointment the day light brought. So he comes back with oh the cam berring is bad on the 450r. Then I tell him the news about the banshee blowing up and the truth on the motor what do u know he calls me 24hrs later and says oh the 450 blew up on me today. Later found out he put 93 in a high compression motor. I was clear with him that it is a high compression piston and it needs 110.
  17. SO MY BUDDY TRADED HIS 450R WITH A BRAND NEW TOP END CLEAN BIKE.NEVER TRADE IN THE DARK.SO THE BIKE SUPPOSEDLY HAD THE LIST OF THINGS BELOW. TUTH IS THAT IT HAS PORTED 100 OVER CYLINDERS MISSING CYLINDER SKIRTS CASES ARE HELD TOGETHER WITH HIGH TEMP SILICONE 21 CC DOMES STOCK REEDS ON PORTED BANSHEE BOYZ CAGES PAINTED REAR FENDER.SO I TOOK THE BIKE FOR A RUN AND BOOM PICS BELOW. PICS TELL THE STORY. ENGINE|DRIVE SYSTEM: NEW WEISO PRO LITE PISTONS .30 OVER HOT RODS CRANK TUSK HEAVY DUTY CLUTCHES AND SPRINGS TRINITY STAGE 5 2 INTO 1 CARB KIT WITH 35MM PKW CARB WITH AIR FILTER AND OUTERWEAR BOYSEN DUEL STAGE REEDS WITH STOCK PORTED CAGES PRO CIRCUIT PIPES TOOMEY RADIATOR WITH RADIATOR COOLERS PRO DESIGN COOL HEAD 20CC DOMES NEW KICK START SHAFT DYNATECH PROGRAMABLE IGNITION http://bansheehq.com/forums/index.php?showtopic=125942&st=0&p=1089096&fromsearch=1entry1089096
  18. Just as it says anyone.
  19. soap scrub pad maybe a lil clr rinse polish and your done
  20. have some pics??? any dents in the pipes or damage
  21. look at my shee in the pic!!! at work we have commercial grade floor sealant and wax.same stuff that keeps the floors shinny in supermarkets. sand with a high grit like 600 then 4 coats repeat the until its mooth like glass then maintain with mild soap and rinse. when they get shitty just sand and do it again.
  22. i have used this kit w/o antiseize and with locktite no problems what so ever. didnt even know i was supposed to use antiseize. also never broke a bolt.
