Powerstroke
Everything posted by Powerstroke
  1. 450 rear calipers are also pretty expensive. Like CJC I used a rf 450 caliper on a homemade bracket. Stock rear bracket I tried to modify to work on the rear next to 450 front bracket my creation is the bottom bracket. Mounted Uploaded with ImageShack.us Probable didnt make the kind of differance the fronts did but still worth the trouble. If anyone knows if a 450 rear is a direct bolt up please post pics.
  2. Maybe you should start with a leakdown test. If you are concerned about air leaks. The "snail" style tool works reallly well for syncing carbs.
  3. Sorry if this is a repost but the seller and the bidders are all crazy.Ebay
  4. Is this mo-gascan on ebay. If so shaddy.
  5. I noticed swingarm shop on ebay is doing roundhouse swingers at a good price. As Matt said you can find used pretty easy with a little patiance.
  6. Look at the right hand side of the main forum page befor it falls out of site.
  7. GOT MY BANSHEE BACK!!!!! (it was stolen before) Glad you got her back. Any details?
  8. lt1bird has a nice banshee based street bike. http://bansheehq.com/forums/index.php?showtopic=112692&view=&hl=&fromsearch=1
  9. My only real works of wisdon on this subject are you will never regret spending money on a roundhouse style carrier.
  10. No idea about the spec but I have no problem with the feeler gauge method. I would recommend putting the feeler gauge in the cyl then putting in the piston and go by feel removing the feeler gauge.
  11. I have the Chariot timing plate that thing is to purdy to hide under the flywheel.
  12. Mainly for trail riding more traction, easier to steer. And any reason to upgrade to a roundhouse style carrier is a good reason.
  13. Nice upgrade!
  14. There is a real good how to pinned in the video section.
  15. I'm gona have to make the trip sometime. I have never heard a bad thing about the place.
  16. How does St. Joes compare to Finger Lakes?
  17. Give this a shot. http://bansheehq.com/forums/index.php?showtopic=112843&st=0&p=983052entry983052
  18. First off the workmanship is top notch. Power wise I would say its less power than adding pipes and more power than adding timing. If I remember correctly it added 25 pounds of compression to my engine. If your thinking of a cool head just do a search on leaks that why I went with the stock modified head.
  19. What part of the state are you from. I run T5s 310 on the main and 27.5 on the pilot. Your probably lean I think Fattys are similar to T5s. Also double check your slides are in the right sides.
  20. I have been wanting to do this. But damn R calipers are expensive.
  21. http://bansheehq.com/forums/index.php?showtopic=105900&st=0&p=916567&fromsearch=1entry916567
  22. Worked perfect on my stock carbs. I think with bigger carbs you will need a different adapter. Check out the vidio thats pinned in the video section.
  23. This is my prefered method. Link
  24. Dave where do you buy your avgas at? Airport in Quincy will not sell it over the counter.
  25. Tell mom to close her eyes until he gets the hang of it.
