if your static compression was 110 before, and it's 150 now, then you raised your dynamic compression a little higher than you may think. now the burn is more on the chamber than it should. ideally, you want the burn more in the chamber, allowing the incoming charge to cool the surfaces more between cubustion cycles. detonation is actually a result of surface temperatures being too high. surface burning really only happens tward the end of the burn, so burning too soon from timing, and too quick from compression, or low grade fuel can cause more heat on the surfaces. high surface heat will ignite the fuel as the compression increases. this is the detonation process which begains the burn from the surface, and accumilates heat higher with every stroke, causing the physical damage. you can combat this by igniting later in the stroke, using fuel that burns longer in th chamber, lowering the compression for a less energetic burn spread, or adding more fuel to cool faster and short circut the burn via lack of oxygen. mid life compression should be a little bit higher on static, which is ok, but when you jumpped to 150, your compression ratio jumped higher, but is giving a respectively lower reading on the test.
