T_Shee
Everything posted by T_Shee
  1. http://cgi.ebay.com/ebaymotors/1996-YAMAHA...sQ5fAccessories seems like a good deal to me
  2. if im at +4 timing and around 130psi on both cylinders should i be running higher octane than 94. im around 800-900 elevation. i have a stock head shaved .015 and a squish of .045.
  3. http://cgi.ebay.com/ebaymotors/G-Force-Adj...%3A1|240%3A1318
  4. yep thats exactly what i was thinking. do u know what position your clip is in?
  5. my arrows are lined up and my clutch is adjusted fine.
  6. your kidding right?
  7. not to steal thread but is the timing plate from rm stator ok? hope so cuz i just bought one on ebay for 25 bucks with 10 bucks shipping. how much are the ones from chariot
  8. yah that was interesting. my buddy had some on a pretty rough shee and that thing was pretty bad in a drag race. i dont think his were cut and it was a j arm banshee.
  9. how easy is detonation to detect and how? and jbones, for future reference either ditch the boost bottle and reed spacers or dont bring them up cuz people around here have lots of negative opinions about them. do a search
  10. what do you mean by push lever? make sure the ball bearing is still in behind the pressure plate.
  11. i cant imagine needing a new rod. is the ball bearing still in there? so you mean you have the clutch screw turned all the way into the nut and still have no clutch? make sure to align the arrows
  12. which side piston is it. it could be a crank seal leaning u out only on one side
  13. all you need is the rust seal paint. im sure the other stuff would work too but not necassary
  14. or if you dont wanna drop a bundle on pc. sand the rust down and paint with this. http://www.kbs-coatings.com/index.html. you can shoot it with a spray gun or just brush it on and the streaks go right away. ive used it a ton and i highly recommend it
  15. those are a good deal. dont know why i couldnt find them. does anyone know if theres some type of glue that would make them stick and hold up better
  16. yeah bandit that is a sweet looking shee. hard to believe those arms are stock, they look so wide when theyre laid straight out like that. flat track i assume
  17. yah i like the decals too. speaking of which where did you get them?
  18. sounds like you didnt figure it out ...thank you for coming.
  19. sweet deal on the filters man. dude is an extremely fast shipper. who needs ebay
  20. well id start by buying new plugs. but sounds like a coil or stator issue. also make sure kill switch and key switch are on. if switches are on and new plugs still wont fire....we can go from there with more diagnosis
  21. T_Shee
    Going Broke?
    the dumbass that bought the cheese balls deserves to get ripped off. man on fire is a good ass movie tho
  22. thats awesome man. wish i could afford a 4 mil. was it like a whole new ride?
  23. no the gas shouldnt go bad that quickly. start with the simple stuff, clean carbs, change plugs, check for broken intake boots or other air leaks. then see what happens
  24. peppy when you build the crap out of them. otherwise they are good reliable torquey trail quad. 05 and newer has reverse too
  25. that is really screwed up.just out of curiosity what you gonna do with the +4 key
