I have a 96' Banshee with a fresh Motor Compression is at 135 PSI (all new seals, bearings, Leak down tested, etc). Here's the problem, I cannot get it statred with the Kickstarter. I've checked and cleaned the carbs twice. Once it's started, it runs like a champ on steroids. I also cannot get it to "Hot start" without Push-starting it. I've swapped the stator, Carbs, and coil from my Bro's banshee and still the same. (My Bro's Banshee has NO Problems.) Pilots are 25 and Mains are 200 on Stock Miluni's. It has Bills Pipes, K&N Filter, 66mm Wiseco's, Billet Water Pump Impeller, and mild Trail Port. I think it may be the wiring. The previous owner deleted all the switches and lights. There's 2 wires spliced together, looks like the wiring to the key...?
