Glamis321
Everything posted by Glamis321
  1. http://cgi.ebay.com/ebaymotors/Chariot-Banshee-Coolant-ULTRA-HIGH-Flow-Impeller-KIT-_W0QQcmdZViewItemQQhashZitem35a2a07b10QQitemZ230361692944QQptZMotorsQ5fATVQ5fPartsQ5fAccessories
  2. Its pretty much a one way valve, it keeps fuel/air from being pushed back into the carbs, but allows it to be drawn into the motor.
  3. ^ this has my vote
  4. Meant more online so I wouldnt have to drive all over the world talking to salesmen. plus I'd prefer private party instead of a dealer.
  5. Looking to get myself a used truck in the next few months, wondering if you guys know of any good places to search?? I've tried craigslist, autotrader/trucktrader and a few truck forums but there isnt much...any ideas??
  6. looks beautiful man. good luck with the sale.
  7. as long as the a-arms are for stock length shocks they will work, but it will make it softer since the a-arms are longer.
  8. I had the same problem with my ATC 250r, no shops around here really wanted to help me. Haven't had much of a problem with my shee though, especially online. You can find just about anything from the site sponsors here.
  9. bump. still for sale.
  10. 50/50 antifreeze/water.
  11. FAST Racing sells them on their website
  12. Sorry but I don't want to separate them if I don't have to. Thanks for the interest though.
  13. I have a set of 6 paddle skat-trak glider tires for sale. They came straight off of a 2001 lt80, good condition and hold air with no leaks. They were only used 4 times a year at glamis for my sister to ride around with. $125 shipped. I am located in Southern California.
  14. yea i have fmf ssts on my bike and they have the same body just with end caps on. those are fmf silencers of some sort.
  15. yea i have noticed that. although he has a couple buyouts as well. He lists 4 mill cranks at 1.99 and then bumps it up himself by bidding
  16. Dunetire on ebay usually sells them, heres a link to a couple he has for 35-41mm carbs. Throttle Cable check his auctions every now and then and im sure he will put one up.
  17. i thought i saw him post something on here about that bike....but now that you mention it i cant find the thread lol
  18. IMS used to make some nice heel guards but i believe they stopped producing them, but you could get some stock ones and put them on, look on ebay you can get them a lot cheaper than what a dealer will charge you
  19. if i remember right the floats should be between .80 and .88 inches so you should be fine. but to raise/lower the floats just bend the little metal arm that the fuel needle hangs on.
  20. x2
  21. your bearing is probably bad. i would replace the bearing and it should solve your problem. also mull engineering has a nice water pump head that fits on the stock shaft so you dont have to worry about the plastic one flying apart. they also have a billet gear too i believe
  22. i have heard of people using stock (26mm) carbs on a 4 mill. Of course it would run better with bigger carbs but it should work temporarily
  23. they definitely have an overflow. the right carb was slowly leaking out the overflow which is why i replaced the fuel needle and seat. i figured i might as well do both carbs and now the left is draining into the cylinder...
  24. the stock pilots are 25s, and stock mains (the big jet in the center) are 200s i believe
