250Rho
Everything posted by 250Rho
  1. jesus joey ive benn tellen you to clean and oil that shit, jus shut up an do it gee i wonder why your filter looks black and yo got no top end :yucky:
  2. ha i know those moments :biggrin:
  3. he started it! :laugh:
  4. one time i nearly ran my friends atv through the front rail of his trailer doin that. i tend to load shit up in the trucks cause he dont like ramps :biggrin: dont feel bad
  5. try fresh fuel and a leaner oil mix i dont know what u run but try a 32 instead of a 24 or a 40 instead of a 32 etc wouldnt go any leaner than 50 also check your coolent you could be burnen it. if you think yourburnen tranny fluid then keep an eye on it! that sucks when you burn all that off and burn up a tranny. i dont see how it could be an ignition problem but i could be wrong
  6. banshees are different then cars, therefore id stick with alcoholbanshee. different engenes different principals,i personaly wouldnt run spray on a engine its like a cheap hooker, leaves you burned up with a feeling of emptyness. :laugh: jus my .02
  7. that head looks pretty sweet hey one of my freinds just bought a warrior with the top end off i was wondering why the rings look like they have so mutch slop and its got a large third ring instead of the two thin ones with the copper seal between like im used to and like i said its got shit load of slop. wtf?
  8. whys second weak, does the gear blow up, or does the shift fork bend, cause dads bent shift forks in yamahas before
  9. that too either way you need to keep an eye on those fluids.
  10. anything steel with a good o ring chain sould last a while
  11. im thinkin about havin him do the cylender on my R if i can get it honed, when the piston blew it left lots of aluminum in the exaust port. i think i want stage 2 lil short on cash right now so im gonna have to wait.
  12. i concur if its easy to get new cases do it mayby you can work on fixing or selling the old ones later if yo can find someone to do a decent job on it.
  13. ive noticed that when you leak coolent into your cylenders that plugs tend to foul very quick :biggrin:
  14. if your running that shit 24:1 id say that im not suprised that you goop up some plugs. i dont think that you should have to change jetting ive gone between diferent ratios before without,and it seems fine :shrug: i used to run a 40 to1 but i think im goin 32 cause the r just burned up on 40 :: ,....not saying it was the mix its just cheap insurence for the new parts. :shrug: i use yamalube, its ok but there are better oils out there that im to cheap to buy if you want to give those cases of yamalube away then i guess i could dispose of them for you
  15. if your going for longevity then stay the hell away from aluminum sprokets and keep to steel those aluminum ones i run wear out fast
  16. lock ons baby :biggrin: 100th post i feel special
  17. stop putting oil in the gas duuu itl stop smoking fo sho!! :yelrotflmao: sounds like you might be burning some tranny oil from a bad crank seal. check the tranny fluid!!!!
  18. i use sproket specialists cause thats the only place i can find sprokets in the size that i need im geard increadebly high because of how fast i need to go and i do it with tiny tires, i use the cheaters way of going fast..... gear it wayy up
  19. crome pipes turn a brown/gold/blue as they get old and hot or if you overheated it etc. only reason i can think of for flames is a bunch of fuel built up in the pipe,if so it should go away after running a while, otherwhise idk if your pipes look diferent then theres a chance your jetting is off frome one side to another , keep an eye on it, things run best right before they blow up. :ermm:
  20. i run ourys on everything but those lock on grips sound like the tits :biggrin:
  21. x2 :laugh:
  22. what do you know about em? has anybody used them for porting and whatd you think.
  23. if you know someone who can tig it thats what id do dont give it to any of my freinds they all seem to think you can weld aluminum with a mig!!! :yelrotflmao:
  24. the case saver can only help. basicly any softer matereal sutch as plastic will help cousion the chain when it winds up on the front sproket and reduce the chanses of case crakedge=my thoughts
  25. i run into the guy i ride with alot, hes pretty stupid and commonly in the way. i try not to hit him too hard i probly would have just let off the gass a lil in thet sitchuation
