250Rho
About 250Rho
  • Birthday 01/08/1992
Contact Methods
    im lookin to buy!
250Rho's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. i soak it doun with 30 wt periodicly and wipe off the exess stay pretty good unless i ride doun a dryed out dirt road then i gota lube it alot
  2. congrats in envyous
  3. i mix the oil heavy ride it easy and jive it the occasional stab and hold then coast, ride some more then stab and hold etc. (by stab and hold i meam going about cruise speed then hold wot just untill you just about top out then let off and coast at idle) this drives the rings into the cyl hard and then the coasting givs it a desent cool doun especialy with air cooled bikes how i do my dirt bikes atvs sleds etc. i have a different metod i use for my street bikes.
  4. whooooo shit aint it the truth that just made my week
  5. 250Rho
    Bear removal
    hahahaha dat b some good shit
  6. itl take a long time youve got a lot of hose to fill with fluid and the master cylender dosent pump air very well takes me forever to do my bikes with integrated rear brakes once u start to get fluid to bubble up it goes fast
  7. gasket sticky is ok but not silicone silicone will let the gasket float around and it will push out when u tork the studs and blow out when u run it for a while as a general rule use the gasket or the silicone not both for cyl.heads always use the gaskets just make sure to tork the bolts to speck in the manual specified pattern and youl be fine
  8. its up to us to keep the legacy of the two stroke alive too true though ^^^^^^ btw luke im yo daddy
  9. put it in a cart man thatd be sick and id be easy and id look right to be doing 100+ in a 150# cart would be the shit thats what id do
  10. so should i go ahead and get a used set of gears and dforks/drums of fleabay btw who do i need to talk to to get a billit 2nd gear
  11. uploads are too slow on my computer it might be awhile for i can get to the grandparents high speed and get em up il try
  12. they make good paperwhights
  13. where can you get a billit 2nd gear
  14. still on the block new seat now has a complete engine rebuild new rod bearings seals top end spare cylender sproket gaskets hubs etc. goes with it looking to get 1k obo rensalear IN
  15. im finnaly gonna sell all my shit build a bansh and im ready to get some cases how important is it to get em without chain damage or repair from it should i be good as long as the tranny dosent leak or do i need to go spend the money on some perfect ones i like the idea of the rz tranny how much do i need just the forks and drum or the gears to, where do i find these parts (none on ebay presently) can u buy all that shit from the dealer still
