250Rho
Everything posted by 250Rho
  1. i soak it doun with 30 wt periodicly and wipe off the exess stay pretty good unless i ride doun a dryed out dirt road then i gota lube it alot
  2. congrats in envyous
  3. i mix the oil heavy ride it easy and jive it the occasional stab and hold then coast, ride some more then stab and hold etc. (by stab and hold i meam going about cruise speed then hold wot just untill you just about top out then let off and coast at idle) this drives the rings into the cyl hard and then the coasting givs it a desent cool doun especialy with air cooled bikes how i do my dirt bikes atvs sleds etc. i have a different metod i use for my street bikes.
  4. whooooo shit aint it the truth that just made my week
  5. 250Rho
    Bear removal
    hahahaha dat b some good shit
  6. itl take a long time youve got a lot of hose to fill with fluid and the master cylender dosent pump air very well takes me forever to do my bikes with integrated rear brakes once u start to get fluid to bubble up it goes fast
  7. gasket sticky is ok but not silicone silicone will let the gasket float around and it will push out when u tork the studs and blow out when u run it for a while as a general rule use the gasket or the silicone not both for cyl.heads always use the gaskets just make sure to tork the bolts to speck in the manual specified pattern and youl be fine
  8. its up to us to keep the legacy of the two stroke alive too true though ^^^^^^ btw luke im yo daddy
  9. put it in a cart man thatd be sick and id be easy and id look right to be doing 100+ in a 150# cart would be the shit thats what id do
  10. so should i go ahead and get a used set of gears and dforks/drums of fleabay btw who do i need to talk to to get a billit 2nd gear
  11. uploads are too slow on my computer it might be awhile for i can get to the grandparents high speed and get em up il try
  12. they make good paperwhights
  13. where can you get a billit 2nd gear
  14. still on the block new seat now has a complete engine rebuild new rod bearings seals top end spare cylender sproket gaskets hubs etc. goes with it looking to get 1k obo rensalear IN
  15. im finnaly gonna sell all my shit build a bansh and im ready to get some cases how important is it to get em without chain damage or repair from it should i be good as long as the tranny dosent leak or do i need to go spend the money on some perfect ones i like the idea of the rz tranny how much do i need just the forks and drum or the gears to, where do i find these parts (none on ebay presently) can u buy all that shit from the dealer still
  16. all these mods making my head spin im getting confused. id like to see a race stock for stock but where the hell are you gonna find a stock banch and a stock zilla in close enough proximity to race. im my oppinion stock for stock is the only fair way to look at it untill i see it i pass no jugement btw luke i am your father
  17. if it aint hers it aint hers dont let that bitch steal your shit cause she feels u owe her sompthing cause u dont! x2^^^^^
  18. need some help bump
  19. plastics too expensive to replace ....rivets and a five gallon bucket good to hear your ok its amazing how far you can fly and not get hurt if you land on your ass
  20. im thinking about going to e85 on the r i think all i need to do is rejet. i believe i would need to go bigger on the mains but i dont want to burn it up so the liklyhood of me actually doing it is pretty small
  21. jus found our what an rz 350 is omg i want one so thats the exact same engine with oil injection and diff trannie gears? are those trannies available on ebay where do you get the parts for the swap?
  22. are u swapping the whole trannies out or just drum and forks or what. im confused how do you put one trannie from one into another does that take alot of machining er are they the same whit diff. ratios so it would be a drop in deal?
  23. why would it overheat with fouled plugs most things ive seen just run like shit with a fouled plug or wont start.
  24. k think il try a b9es that should fix me up
  25. from reading that article id say i need the next colder plug ey btw wats the next coldest to a b8es i think its a b9 or is it a b7 im not sure.
