bansheeqc
Everything posted by bansheeqc
  1. Tyler, you know: the second is the first looser! lol just kidding. Nice vid here. What speed you came at the top of the hill? what is the Time with the 450? it's the 10mill cub or the DM? Do you have the vid of the guy with the 750 triple?
  2. I finaly put some ATF type F in my trail bike. Seem to run well. Thank you for the advices.
  3. But the 10w30 Car oil not work? Use ATF type F for trail riding in stock tranny will hurt tranny or clutch?
  4. I usually run yamaha or honda trans oil on my trail banshee and ATF type F on my drag banshee. But a friend of mine told me to use 10w30 or 5w20 standard motor Oil on stock banshee tranny. I do a couple of research on the forum and find a couple of topic, but not exactly what i want. I want to know if the standard motor will may hurt something. I know motor oil contain detergent, may have problem with this? 10w30 or 5w20 for trail riding and open log road riding? How often for Oil change? I have a gallon or so of castrol GTX 10w30 in my garage, this oil probably do the job? thank you
  5. Are you 100% sure of that...????? A nikasil co. in my area told said to me: no plating on steel sleeve. we have to switch the steel sleeve for aluminium one to get it plated
  6. Yes Roger, i'm happy with them. The only bad things of this pipe, it's the springs to keep together the pipe, came loose all the time...
  7. I looking for some input to compare the conventional lockup style (Direct drive, matoon, modquad etc) VS the slingshot,vito...style lockup. I think for the price, the slingshot is best, but for tuning? With no quick cover, it's more complicated... So, for holding HP and have the capacity to slip out of the hole, but hold after, DD or slingshot it's the best??? thank you
  8. From RDZ website: http://www.rdzracing.com/pictures/Drag_pipes_Dyno_GRR_vs_RDZ.jpg I personnaly run GRR oof sb sf on one of my bike, and I love them. I also have shearer and love them too.
  9. I see a couple of cheetah on the dyno, with many kind of pipe. a 421 cheetah drag ported on alky with oof cpi as 100rwhp (dynojet dyno) a 472 cheetah on gas (50/50) with inframe CPI around +/- 85rwhp a 421 cheetah on gas (pump), with t5, small carb run in the 75+ area I thing you need to have around 75 or more with your actual setup Do you have one or two 38 carb?
  10. maybe you have a lil gasket thickness variation, maybe explain a part of the 0,053 vs 0,050
  11. http://cgi.ebay.com/ebaymotors/drag-racing-banshee-_W0QQcmdZViewItemQQhashZitem4cefdaf09aQQitemZ330441617562QQptZATVs I never see pipe like that.
  12. What is the tension of the different clutch spring on the market? I know RDZ is 85 pounds Toomey is 70 pounds barnett? stock? thank you
  13. I run 1-5 neutral down duneable override cut by WCR.
  14. Any picture? It's a twister monoblock? Maybe interested!
  15. alcoholbanshee is a really good seller to deal with. I buy a set of pipe and a billet basket from him. I received the item very well packaged and like as described.Furthermore, He ship and reply to pm Fast!
  16. Thank you guys for the information! I finally get the 7 bolts for one of my bike. Bansheeqc
  17. What is the difference between 7 and 12 bolt? and if i have a great deal on the 7 bolt, the best is to go with 7 or 12? thank you
  18. If you send the cub to millenium, you are able to put a larger layer of nikasil, and run 64,50 piston on that. A guy in my area do a thing like that for a motor and dowsized the bore by 0,5.
  19. Thank banshee332 for the informations. I'm looking for 500ft time because in my area, a couple of guy think 4wheeler are slow, and i just looking for comparaison between sled (500 feet grass) and i want to compare on the same distance. bansheeqc
  20. Thank, JMADD , i wait a couple of day, if i have any replay, i will PM banshee332
  21. 45 view, 0 answear anyone kwnow?
  22. I'm looking for time in 500 feet dirt. Post your ET, speed and what kind of banshee do you have. thank you bansheeqc
  23. I have a set of 36mm keihin carbs. How to differentiate PWK from the airstriker? PWK slide may fit on airstriker and airstriker slide fit on pwk for same diameter carb(if a have 36mm pwk and 36 mm airstriker for example) Thank you Bansheeqc
  24. In my area, a guy claim is banshee have 120 horsepower at the wheel. A week ago, at the truck pull show in my area, the guy race his banshee vs 2007 gsx-r 1000 The track have 887 feet GSX-R ET: 9.002 MPH: 101.71 BANSHEE ET: 9.739 MPH: 86.72 I think with this time, noway this guy have 120hp What do you think?
