350BANSHEE350
Everything posted by 350BANSHEE350
  1. also i am wondering if a tire that 20x11x9 would fit on stock rims (20x10x9)?
  2. anybodu have a site where i can read about tis ATF type F stuff and perhaps a pictue to see what the bottle looks like greatly appreciated
  3. im looking for tires and i look at the price for some holeshot xcr tires and it says its $160.95 somebody please tell me this is for a pair http://www.partscanada.ca/catalogue/2007/atv/en/index.html
  4. whats "better" to run? yamalube 24:1 or 32:1 i would think 24:1 because it has more oil for lube
  5. would i foul my plugs running 24:1 with yamalube all stock bike BTW
  6. how rusted? if there not to bad then you could sand them down and paint them silver or chrome or black etc.
  7. http://www.americanmototire.com/index.html...rget=d1035.html
  8. http://www.valvoline.com/pages/products/pr...l.asp?product=7
  9. http://www.valvoline.com/pages/products/pr...l.asp?product=7
  10. whao it says it has friction mods in it that creates clutch slip http://www.valvolineeurope.com/index.asp?p...606d0f237d8da9b
  11. well then i think ima run this stuff here valvoline max life 10w-40 thanks guys oh were could i pick some up? just at a local car shop with oil suplys?
  12. bigger jugs of car oil are cheaperthan big jugs of yamalube buy far its 6.50 for a 36 oz bottle here in canada
  13. also i forgot to add that im running yamalube right now ... im going to run it at 24:1 thats heavier than 32: right
  14. my dad wants to run car oil 10w40 in the tranny i know to not buy some withfriction modifiers but what else is there i should check?...is it bad to run car oil? also i want to knw about these 3 oils castrol R30, A545, A747 these are in the manual for what to run and im wondering what one is best thanks
  15. i like these tires... what are they made buy? how thick are they and how puncture resistant? is there a website that gives info about them thanks
  16. whats the mix with this engine ice and water wetter stuff? would it be good for the trails
  17. ok thanks what about if you pipe it jet it and put vforce3 reeds on i still probably about the same i would think buying a compression tester later down the road would probably be a good idea right? how much are they?
  18. how many hours should it take for my 07 o need a new top end rebuild? thus being perfectly jetted and running yamalube at 32:1 thanks
  19. on my buddys 250r trike you can adjust that and same with my friends dirtbike
  20. i dont like the way my clutch is right now... its hard to explain but ill try my best. ok so i pull in the clutch all the way. then i let it go slowly to find where it grabs and starts to go it grabs at the last centimeter on the clutch lever... i would like to have about 1-inch of play were i can slip the clutch then only 1-cm i would like the clutch to grab after 1-cm of letting it out but it grabs after 1-inch of letting it out so in other words i dont have much clutch play or slipage hopefully you understand that if not ill try it again thanks alot
  21. well theres 2 pt pipes but the pt mids give really good bottom end and mid and the pt revs give more top the t5s give better power if you have it ported and other stuff like that . i dont have experience with either pipes but its what i have seen
  22. i think it might be a kinda of greace to make a better seal
  23. i was looking over my banshee today and i realized there was a wierd brown liquid coming out of the top of the cross over tub rubber seals it smelt like ass i whipped it off and i know its not mud because i havnt even ridin the bike yet... its a new 07 so can you please help me figure out what this is? it wasnt spewing out it was just sitting on top of the seals thanks for any help
  24. yea but if you change the rear sprocket dont you have to pull the spindle of the rear?
