bonbon
Everything posted by bonbon
  1. BUMP! Killer bike scary fast. Next time you come out if you have an extra couple hours you should get me motivated and help pull my motor. That way I can get my porting done and put that death override in.
  2. I'll trade you my dodge (minus a working transmission) and two stock cylinders. One cylinder cherry and the other with sick ass nasty holy shit what the fuck happened oh it was a circlip gouge in it. Both are on stock bore. Take it or leave it. I suggest you take it for everyone's well being.
  3. I bought a duneable override off of Gary a couple weeks ago. Good deal, quick shipping, and easy to deal with. It showed up exactly how he described it to me. Thanks
  4. I'll pull mine out and trade you for them.
  5. Are you going to the University or Tech?
  6. I'll be hitting up Killpecker if I am in town. It is looking like there is a good chance I will have to work though. Shoot me now. I don't work during the weeks, then get swamped on weekends. Figure that one out.
  7. Sure, but I'll still take it. I need a new phone pretty bad,
  8. I'll take it. How much to ship to 82901?
  9. It's both of them that bother me. I don't think you can unbolt the one over the flywheel, can you (well besides to get to the flywheel)?
  10. Dang it, I'd be all over that without the cross in it. I guess I should add that I prefer it to be blank, maybe with slots or flames over the sprocket area.
  11. What do people have they are willing to part with? I hate shiny shit but the stock cover is starting to bother the fuck out of me. Let me know. Money in hand (or paypal for that matter).
  12. I think you are thinking of Ricky Stator. There have been tons of complaints there. RM is a Canadian company (I don't know maybe they get there stuff from the same place as Ricky though). I bought one, never installed it, then traded if for some powdercoating so I can't attest to how well it holds up. For $100 though and I got it overnighted from Canada off of Ebay (actually got it the NEXT day, which is amazing), I think they're service is pretty good anyway.
  13. DAMN! New 4 mil crank for $350??? Nice!
  14. PM BoostedRex on here. He usually has a set or 2 laying around.
  15. Not the thread size, but the piece of brass above where the main would screw in is what I am talking about. i.e. the size of the hole in the main jet not the threads. So the size of the hole through the dump tube. I'm not very good at explaining things let me go find a diagram. http://www.sudco.com/Diagrams323728/exptm.gif The part that is drilled out and not changeable in a PWK is 37 in this drawing of a Mikuni TM carb.
  16. Not sure on the threads deal. Find yourself a drill bit or something that is .125" (1/8") in diameter and see if it fits. If I remember that is a common size that the dumps are drilled to. That or .120", I can't remember for sure.
  17. The dump tube is where your needle drops into and the main jet screws into the bottom of.
  18. I think you are screwed. Keihns have to have the dump tube drilled out as it is not removable itself. If it were Mikuni you can buy different sized dump tubes and switch back and forth between gas/alky.
  19. C'mon Kiel, keep it wide! I only bent 2 tie rod ends a couple weeks ago up there because I didn't throw on my stock fronts and skinny up a bit. Bump for a good deal and dude!
  20. bonbon
    Killpecker
    Cool. I will see if I can get out there sometime during the week. The dunes are at about 7100 feet so I would plan on dropping at least 1 main most likely 2.
  21. Well yeah with the weight savings of no cylinders.
  22. Plugs backing out is usually going to be detonation. With those 19 cc domes at sea level I would be a little concerned that detonation is the problem. Are you running 91 or 93 pump gas? Does your compression tester fitting screw into the dome as far as your plug does? If not you won't get an accurate reading. I don't have the correct adapter for mine but figured it to make ~1cc difference. i.e. a 19cc dome would actually be reading like it was a 20cc dome. About the ticking I'm not sure. My motor from stock, to cub, now to a fully rebuilt (bearings crank clutch everything) cheetah still makes a ticking noise I have yet to figure out.
  23. bonbon
    Killpecker
    By the way, what part of Wyoming are you from??
  24. bonbon
    Killpecker
    I may be able to make it out depending on when you leave. I just got swamped with work (14-16 hours a day) until probably next thursday. If you are out there until the next weekend I could probably make it out and go on a few rides with ya. I don't know who you are talking about.......when did Rick get a 4 mil cheetah? :biggrin:
