Order a flywheel puller from whoever you are getting the plate from.
You need an impact and a 16 or 17mm socket.
Pull the peg off, pull the shift lever off, pull the cover off, buzz the nut holding the flywheel off with the impact, use your flywheel puller and pull the fly wheel, 3 screws to get the plate/stator off the case, take the stator off the plate, put stator on new plate, put plate on, use blue lock tight on all screws, set your timing to where you want it by lining up the timing mark up on the plate with the split between the cases....reverse order for the rest of the stuff....its easy.
Dave
