Dave I.
Everything posted by Dave I.
  1. only thing I can think of is it might be harder on the rear axle when turning. the inside tire is trying to turn faster than the outside tire causing a twist on the axle. Im not sure there is enough weight on the tires to really matter though.
  2. In the front might cause you loading problems depening how you haul your bike. Also you typically crash with the front end first so if its sticking out there, chances are its going to be your bumper. On the rear its more leverage if you flip or wheelie to bend your subframe. Not much more than a grab bar but a little.
  3. youre gonna love the meth tony...its fun.
  4. how does your basket look? maybe its not able to disengauge?
  5. its a 392 Steve. I just switched over to alky a few days ago so still tuning it but its running ok..should be fun.
  6. ill be out there...look for the guy one the black banshee that cant ride worth a damn.....
  7. cam, cykotik was lookin for some black plastics
  8. http://www.yfzcentral.com/invision/
  9. just make sure you get rainbow colored lights cause if neon lights on a banshee isnt gay, i dont know what is.
  10. I dont see all the 450 guys bragging about beating a piped banshee...maybe its just me but seems like a lot of banshees have little man syndrome...450 guys dont have the complex that if they dont beat a banshee that they are less of a man....I dont know if this is true everywhere but from what ive seen it is.....good for you if you can beat one in a straight line......go race one on a trail or mx and see how you do, if you can walk the next day.
  11. some guys also grind the bowl drain nut down a little....get like another 1/16" clearance
  12. i just switched to type f automatic transmission fluid...working fine so far.
  13. ttt for a good seller.......moneybags is a good guy.
  14. Dave I.
    39mm intakes
    looking for some 39mm intakes, what do you have?
  15. checked today and im not sure what brand it is but it doesnt have any additives, and its $200 for 55 gallon drum. everything cost more here lol
  16. damn, did they use the whole tube? i put like a little 1/4"bead all around mine and it still squished out.....they must have ran that on there like a fat bead of silicone...
  17. tony, those should be good for you, from what ive gathered .125 is about as big as you want to be max, then you can mess with main jet size......call john or someone and see what they think.
  18. Looking at the vp website I see, m1, m3, m5.....what do people normally run in a banshee? thanks dave
  19. Looking for a valve stem cap off of a left rear tire for a 97 banshee
  20. im still dialing it in but ive got a 392, 35 pwk, 155 mains, 50 pilot, 185 psi and shearers.. i know its not what you asked for but maybe some sort of idea??
  21. Buy an expensive cover so you can get to it without taking the cover off.....direct drive makes them If the oil smells burnt then maybe the clutch adjuster came loose and lost adjustment and you fried your clutch in the process....take it apart and look at the fibers and steels.....if the steels are dark color and burned then its time for a clutch
  22. Yea, what he said.....From what I understand Calvin had wiseco design a piston for a stock crank/rod combo for the 68x54 cub. It is sold through tinity and has an odd ball part number. They are a little more expensive than the usuall 140 or whatever standard wisecos cost....cost a little more and have to order them but how many people really go to their local dealer to buy pistons anyway?
  23. why dont you be the first?
  24. cant decide what you want huh...well if you get a +8 swinger ive got some alky carbs ill sell ya lol....
  25. Got the bolts. Thanks. The Post man must have a banshee also because someone took out the stainless allen heads, only left me 9 in the whole box.
