right on either side of this marker, you see the pointer on the case, and the pointer on the lever.....
they should line up when NOT pulling in the lever.
In the middle of the clutch preasure plate, you will see a nut with a phillips screw in the middle, I think the nut is a 10 or 12mm, put a screw driver in, then loosen the nut. Turn the inner screw either foward or backward to adjust the lever on top in the picture with your clutch cable slacked. Once you get it right re tighten the nut and then re tighten the cable just enough so as to not engage the clutch untill you pull the lever.
