Everything posted by kaotik1
Custom Polaris 90cc Race Quad
kaotik1 replied to Wheel_Works's topic in For Sale - Parts & Accessories
That thing looks like fun! Good luck with the sale, should be a great deal for someone. -
Okay guy's I have decided to sell this project. I will be taking a loss on it, but I know someone will want this. I am looking to get $3800 for it. Feel free to ask questions, I will answer them all. To get this thing running you will need the following parts. 1. Airbox with the battery re-locator 2. Chain, I think I may have an extra though 3. Axle nut This thing has not even been fired up since the motor was rebuilt. To make this think pretty much show or track ready you will need the following 1. Plastics, the stock yellows aren't the best against the orange. 2. Tires to go on the the extra set of powdercoated rims. 3. Shocks for the front, as it has stockers on it now, just to hold it up. It's a 2002 400ex 2002 400ex gusseted and powdercaoted frame with title. ASR pro +2+1 black braided brake lines front and rear I have stock rims powdercoated black chrome need tires, but I also have the stock rims with tires on them. All new bearings throughout, the bike Stainless steel swing arm bolt G-force +2 axle Sub-frame now has a removable grab bar battery box tabs removed, so this will need the relocation box for the battery. Houser racing +2 stem with anti-vibe fat bar ASV levers clutch and brake Larger oil cooler coated black chrome. The motor is a 426 hi-compression JE piston stage2 hot cam, with the stronger timing chain. Cometic head gaskets. The head pipe was hi-temp coated polished silver, heat shield black, and the can black. Here are a few pictures http://northeastcoatings.net/tj/IMG_6946.JPG http://northeastcoatings.net/tj/IMG_6945.JPG http://northeastcoatings.net/tj/IMG_6944.JPG http://northeastcoatings.net/tj/IMG_6943.JPG http://northeastcoatings.net/tj/IMG_6942.JPG http://northeastcoatings.net/tj/IMG_6941.JPG http://northeastcoatings.net/tj/IMG_6940.JPG http://northeastcoatings.net/tj/IMG_6917.JPG http://northeastcoatings.net/tj/IMG_6898.JPG http://northeastcoatings.net/tj/IMG_6753.JPG I have a ton more pictures if you want to see something just ask. I may even concider a trade for a 4 stroke bike..
Hurt-Ten ton brick Five Finger Death Punch- The Bleeding Clutch- Electric Worry
Okay guy's I have decided to sell this project. I will be taking a loss on it, but I know someone will want this. I am looking to get $3800 for it. Feel free to ask questions, I will answer them all. To get this thing running you will need the following parts. 1. Airbox with the battery re-locator 2. Chain, I think I may have an extra though 3. Axle nut This thing has not even been fired up since the motor was rebuilt. To make this think pretty much show or track ready you will need the following 1. Plastics, the stock yellows aren't the best against the orange. 2. Tires to go on the the extra set of powdercoated rims. 3. Shocks for the front, as it has stockers on it now, just to hold it up. Thanks guy's Tj
Please leave me feedback. So others know how I operate. Thanks, Tj
Trade: My Race Ready 400ex for larger Quad or Nice Banshee
kaotik1 replied to jeemann99's topic in Swap and Trade
Other than the bore that bike is STOCK... Not bashing just letting you know that is not near race ready. -
The rear doors have a handle on the inside of the jam. Those are suicide not the front doors.
I have done more than a few jugs, they are fine with low temp bake offs. I have heard that nikosil is bad to bake off and coat, but I did a set not to long ago, and have not heard back. I assume they are fine. Why not bake off the side cover? As long as it is not a magnesium cover it will be fine.
Ratio rite cup! I ran 32:1 with the maxim oil, and 80w maxim tranny lube.
Stock shocks don't have much to adjust. You will need to just turn the body to full pre-load. I would suggest a set of works or something cheaper with more adjustabilty. If you want to concider something like that I have a set of triple rates, that will work out great for you.
You should use a sandblaster, they get into all the little areas you cant touch with paper. It will not really affect the how the powder sticks if you get it right. The bake off is more important because it gets all the oils and such off the metal.
It should yes. It may not flake up but sandblasting afterwards is suggested.
Paint will actually bake off at about 400*
You can bake it off by placing the item in the oven you are using, turning it up to 600* and let it stand till the powder begins to flake. It will look like a chared marshmellow.
I realize my truck looks are not for everyone. If they were it would not be "MY" truck. So far I am pleased with the way it looks, at one point or another there were things I didn't like I fixed them and moved on. I tried several hoods before settling on this one, in person it looks better than the pictures. My back seat the base lifts up just the same as you described, I wanted more than a 10" sub. I opted for the 12" the enclosure was a pain to build it had to have poly fill to trick the sub as well. I did not have to lift the seat base to make it fit either. There are a few companies out there that make boxes for these trucks to fit 12's without the seat being moved.
New guy needs parts... plastic, chain, lots of misc.
kaotik1 replied to istoleacamaro's topic in Wanted
I have a Sidewinder ti-moly sprocket set 15t front and 41t rear, with the ti- chain if you have any intrest. I think that is the sprocket sizes I will check later this week. I also have a stock length swinger powder coated Vein Red. -
Thanks for the UP! He's pretty close so there won't have to be shipping.
Not really much to like if you remove all that stuff :laugh: I do not have pictures of the sub enclosure, hard to tell what it is anyhow, I carpeted it to look like the factory storage box.
I may have a set of blue full with seat, tank cover and rad cover.
Thanks guys been hard up to this point, too many projects lack of time and funds. We all know that one! haha This truck is a 4 door, the rears are suicide doors. Just not a club cab, those are denali's! Like this one, and since you all like the supra heres a sweet one.. The supra is for sale as well..
Here is my truck and a list of whats done so far. 2003 awd with 38k black Exterior- Reflexxions cowl hood carriage works billet grill powdercoated black chrome Extang full tilt bed cover factory bed liner Brake and suspension- Belltech lowering spindles up front Belltech lowering leaf packs in the rear Belltech nitro shocks Bear Alumasports with 2pc front rotors up front Bear Alumasport with one piece rotor in the rear Earl's braided brake lines (5pc) kit Interior- Clarion Vrx935-VD DVD/mp3/cd player Flip out touch screen JBL pb-1200.1 amplifier Alpine Type-r 12 inch subwoofer with fiberglass enclosure no seat spacers Playstation2 with wireless controller Bolt-ons- Revolution Raceworks Tune K&N cold air intake powdercaoted black chrome magnaflow catback dual in single out factory location (stainless) ASM headers(long tube) heat treated titanium color cross over pipe with high flow cats, to match up to the factory exhaust (heat treated black) http://northeastcoatings.net/tj/IMG_7056.JPG http://northeastcoatings.net/tj/IMG_7057.JPG http://northeastcoatings.net/tj/IMG_7059.JPG http://northeastcoatings.net/tj/IMG_7060.JPG http://northeastcoatings.net/tj/IMG_7061.JPG http://northeastcoatings.net/tj/IMG_7062.JPG http://northeastcoatings.net/tj/IMG_7063.JPG http://northeastcoatings.net/tj/IMG_7064.JPG http://northeastcoatings.net/tj/IMG_7065.JPG http://northeastcoatings.net/tj/IMG_7066.JPG http://northeastcoatings.net/tj/IMG_7068.JPG http://northeastcoatings.net/tj/IMG_7069.JPG http://northeastcoatings.net/tj/IMG_7070.JPG
Looking for pics of orange and blacks shee's
kaotik1 replied to Canadarider's topic in General Banshee Discussion
I am waiting on a few parts. Plastics, shocks, and airbox. It will be done. My paypal account got all jacked up from someone trying to get into it, so all the money I have there is suspended. Trust I want it done, so I can trade it for a dirt bike. haha -
I don't have plastics yet, but this is a shot of my ex orange and black. -
Sending you a PM, I may have just what you are looking for.
This one will get you slapped... If you have lost your virginity, Can I have the BOX it came in???
