okbeast
Everything posted by okbeast
  1. An MX/play port, maybe a single 35pwk carb, raise the compression and timing.
  2. A-arms and shocks price shipped? Don't wanna screw anyone out of getting this bike, but you'd get ALOT more than $2700 for the bike whole, and for parts.
  3. Carbs :thumbsup: http://www.bansheehq.com/forums/index.php?showtopic=106523 Hit me up, we can work somethin out, need to get rid of.
  4. Same. Did you say you were in school? Where?
  5. There's quite a few aftermarket radiators out there that are smaller that people put on their drag frames, I would assume they have all the correct line hook-ups. Just something else to check into.
  6. Front end down doesn't = good traction, lol. I'd say with that long thing you could run 12 paddles and even be ok.
  7. Pics of the Shearers, and what's so "rare" about them?
  8. Great price on the cyls., reeds and coolhead. Good luck with the sale :thumbsup:
  9. Definitely Ricky Bobby. Or like an Air Force or old War plane theme. Seen a few of those and they're badass.
  10. That's gonna be one heck of a duner! I'd ask a builder or someone else on this one. I'd say maybe a billet 2nd would be a good idea, but I'd ask someone who builds the overrides (assuming you're getting one of course) how they would hold up.
  11. When is it?
  12. What's the bike going to be used for? As for bearings for the crank a TZ bearing would probably be worth the money for the PTO side, unless you're gonna go to straight cut gears.
  13. You should teepee him for sure. :biggrin:
  14. I got some off ebay. Ad said it was for 16 and I think they sent 20 or something, with washers. Lolzer at you asking for EGG CORN nuts and getting mad when they sent you the wrong thing :yelrotflmao: :yelrotflmao: :yelrotflmao: :yelrotflmao: :yelrotflmao:
  15. Does anyone know which fibers he uses? I do remember someone thinking they were the FZR1000 ones I believe, and his setup is cheaper than buying all the stuff separate.
  16. Now guys, Mr. Ohton has worked very hard to keep PS running smooth and everyone knows it takes a couple hundred THOUSAND dollars to run a website as good as it so go easy on the bashing. :: :shoothead:
  17. Get a compression tester if you don't have one and do that 1st. It'll tell you quite a bit.
  18. Yeah the slingshots are good, I haven't personally used them but know of alot that do. Did you get the under the stock cover one? I would do a compression test 1st before thinking about a rebuild. Unless you sucked in some sand or leaned it out it shouldn't need a rebuild.
  19. Yeah I would say it has worn the clutch fibers down. You're going to need a lock-out at least for a 4mil cub. I am running one without an override, which alot will say is dumb, but it works great for me, still shifts fine when I wanna drag and it's perfect for duning.
  20. What's your complete setup, motor, carbs, suspension, everything. That would help out some.
  21. I would guess somewhere in the 155-160 range for mains, 50-55 or w/e pilots come in, not sure on the needles I haven't messed with the keihin's that much. What makes you think it's lost power?
  22. His fault for bein in the way right? Just pin the gas and ride over him.
  23. $330 shipped for carbs AND filters.
  24. Who's bingo? Been hangin with michael jackson any lately?
