woodro77
Everything posted by woodro77
got my new ball joints from ricky stator , they fit perfectly .
i have raced a lt 450 with a cherry bomb and yosi pipe and it was very fast , it was a very close race almost even , but i have more top end so i would pull on him at the end if its a long race. my brother has a trx 450 with a hrc kit and it is very fast he used to beet me before i got my new carbs (30 mm) , now i take him by a bike or 2 , my mods are trail port , v force 3's , 30 mm pwk knock offs , +4 timing advance ,toomey t-5's , k +n no lid , so my banshee is pretty fast , i have no problems beating stock 450's but when they started adding mods they really are fast , i havent raced a 450 with a big bore kit yet and im not sure i want to.
if it has 475 dollar port job and 35 mm carbs it probably has a pretty agressive port job , probably not going to be very trail friendly , unless they open fast trails , might want to think about a 2 -1 carb , will give you a little bottom end power , paul turner mid range pipes will give you some bottom end power for trail riding , t-5's are awsome pipes but they are made for top end power .
i shipped a frame last week with FED-EX and it was under a 100 bucks , i live in NY and i shipped it to california .i just shrink rapped it and sent it . a lot of guys use greyhound i have never used them before but i heard its cheap too. UPS sucks , they are always more then FED-EX.
thats how you do a comp test , 30 psi i am surprised it even ran . as for the rebuilt take your time , get a repair manual and it is a piece of cake . BIGRED350 has a step by step rebuild with pictures in the repair and mod section ,do a search .im sure that will help out alot . it helped me get the balls to do my first complete rebuild
i go there 4 times a year , that place is great . have you ever been there before ? if you are looking for good trail riding i wouldnt go to rauch creek , i would go to TOWER CITY , which is right down the street from RAUCH CREEK , rauch's trails arent that good , that tracks are awsome though.
Oil from trans coming out of overflow tube
woodro77 replied to bansheeboy02's topic in Banshee Repairs and Mods
oil was coming out of my over flow once right after the motor was built , the builder did not use enough sealant (yamabond ) in between the cases , was leaking right behind the crank , rebuilt it myself and it is fine now. -
i have a pep steering stabilizer and im sure it bolts up the same , 1 side bolts to one of the 2 motor mount bolts that go to the frame , and the other side bolts around the steering stem , pretty easy to install
i got the new needles from CPW and it runs alot better , it did have a bad bog just off idle , now it is very slight , maybe i can clean it up with air screw or clip position , i will mess with it tomorrow , i called them like 5 times picking the guys brain , he was very helpful , and he sent me different needles for free , i expecting them to say go fuck your self , but they fixed the problem .
i believe it , that is a good gun , when i was buying mine the salesperson told me to buy that one , i just looked it up it is only 199 bucks at SEARS , 625 foot pounds of torque ,
i have used that gun before , its a good one , i was going to buy it but it was a little expensive , 300 bucks i think or close to it . mine is a ingersolrand # 231 i think
i have a ingersolrand and im happy with it , it has more power than i will ever need , i think 660 foot pounds , never had something it woulnt take off , it wasnt that expensive maybe 140 bucks . with ingersollrand you have to be careful because they make ones that are made in china that are not as good (the ones Lowe's sells) . i also have a battery operated impact gun and i will tell you i am very in pressed with it , alot more power than i would have ever thought , i use my air gun alot less now , i save it for the big stuff , every thing else i use the batt opt. gun . pain in the ass to fill up compressor to take off 1 bolt .
you said last time you rode her was 6 months ago ? first check to make sure you are getting spark . sounds like you are , if it ran dumping gas into motor and it started . could be old gas , clogged jet , gummed up carbs , take the carbs off and clean them out , make sure all jets are clean , could also be choke crossover tube , (black tube that goes in between the 2 carbs ) make sure that is there.
1/4 inch is a little thick , usually they just add a piece right next to the stock one , someone had pics on here once of banshee gusseting , maybe BIG RED 350 if i can remember right
Intake + Keihin 35mm PWK carburators
woodro77 replied to Al_Scrap's topic in For Sale - Parts & Accessories
did you use paypal ? -
true im just going to get them
yes , ricky stator said they have both styles , for reamed spindles and stock spindles , i measured the ball joint with a caliper today and it is 16 MM so i guess i will order ricky stator ball joints . does any body know where esle i can get these ball joints from ? rickystator wants 20 bucks a pop .
i have much to learn ? what the fuck does that mean ? i am trying to find my ball joints and having trouble , they dont thread into the arm , so the diameter just has to be the same. and i dont have a caliper that measures MM , thats why i posted this question. thanks for telling me to get the right joint though , thats the information i was waiting for , helps me out alot. ::
i believe in spanking to a degree , my father was a Marine Sargent , he was very fast to give a slap when i was out of line , some kids do need it , but it can get out of line , it does have an effect on a kid , when i would go to school i would fight alot , when a kid wanted to fight me i would fight on the drop of a dime, i would think this kid is 100 pounds how can he hurt me when my father hit me and he was 220 , and the fighting went on for years into my 20's , all built up anger like a fire burning . so be careful how you punish your kids .
kick starter wont move how do i fix?
woodro77 replied to dangerous_banshee's topic in Banshee Repairs and Mods
i have never had a motor with nothing wrong with it lock up , if its locked up it time for a rebuild. i wouldnt try poping loose kicking it as hard as you can , you are going to do more damage . loosen the head up ? wouldnt be easier to take out the spark plugs -
i think its thirsty in the middle to , it runs the best when i put the clip closest to the pointy end (richest ) , and it still isnt rich enough , next size up on the pilot and it gets worst .
yes they are a pain in the ass to fit , watch out for tears in the boot and air leaks. i have talked to about 8-20 people that got these carbs and the all got the same jets , 155 main 55pilot , from guys with stroker motors to totaly stock motors got the same jetting . did they come with extra jets ? let me guess , 150 , 160 mains , 50 pilots , they are nice carbs for the price , they are accualy made by keihin , just dont have the name because of copyrights or something , mine were great untill it got warm out now it has a bog right off idle . when they were good they pulled like hell , way better then stock carbs . my mods are , trail port , v force reeds , +4 timing , k+n no lid , toomey t-5's . they are sending me new needles , hopefully this will fix the bog im getting , they said they never had this problem before.
i have them , they were awsome when i got them (winter ) , now that it warmed up i am having trouble dialing them in , i have to say though CPW is great with help , i called them and told them whats happening and they are sending out different needles for free , what jets did yours come with ?
well 5/8 is the thread size of the ball joints for my +2 a arms and im trying to find new ones , ricky stator says their joints are 16 mm thread , so im tying to find out if they will fit on my arms
what does 5/8 of a inch transfer into MM
