ok, i've got a big mystery problem. the cylinders aren't gettin gas. well, here's how it all started. last time i rode was late september 2006. put the banshee in the garage so i could start on installin the new lonestar swingarm. went to start it up about a week ago and it took a good amount of kicks to get it started. went to start it 2 days later and it fired up a little easier. went to fire it up 2 days later and got nothing out of it. i did a compression test and both cylinders held at 122 psi. hopefully thats good. i cleaned the carbs 3 times. still nothin. i made sure the gaskets in between the intakes and v-force and cylinders are all good and they are. checked to make sure the reed petals aren't cracked and they aren't. the floats are operating correctly. i'm gettin real good spark and gettin fuel to the carbs but no fuel to the cylinders. i tried to put not even a cap full of gas in the cylinders and it fires up on first kick, i don't know if thats good but after it fires up, it bogs down and shuts off. i turned the choke on and it hits perfectly with no hesitation and will continue to idle perfectly but with the choke off, it hesitates real bad and then shuts off. if i wait till the next day to start it, it won't start at all. i checked the rubber boots on the billet intakes and they don't appear to be torn. however, i didn't empty the gas tank over the winter and the oil more than likely settled at the bottom of the tank and is probably preventing it from starting but it still started on the first day i tried to start it. i got new gas, 93 octane (thats what i've always used), mixed at 40:1 and drained out the old gas, still got nothin even with new gas, but i didn't clean the carbs AGAIN. i hope the crank seals aren't bad. the cylinders aren't ported and the heads aren't milled. someone told me it could be electrical but i don't see that being the case. my next option is to clean the carbs again, then try to start it. i'll order some new gaskets for the v-force and intakes and some new rubber boots for the intakes just to make sure they aren't torn. until then, help would be very much appreciated becuz i have a score to settle with some chump who thinks he's faster than me after he bought new tires when i've bought damn near a whole new rear end suspension and new bearings all around and a new sprocket and i've already smoked him by at least 10 bike lengths on more than one occasion and oh yeah, he has a banshee with all the same mods except he also has his ported, milled and 34 kehin pwk's. my banshee is a real screamer and i'd like to have it that way again but this little mystery problem is really pissin me off. thanks for the help
