trickedcarbine
    165
Everything posted by trickedcarbine
  1. Best case saver ? Cotton branch.
  2. Baseball career? It's only a career when it pays the bills.
  3. So, won't name names on those bowls then? Caugh, Ch****t, caugh....
  4. Depends on whether you buy arms for stock spindle or his cup style that directly takes the shaw.
  5. http://bansheehq.com/forums/index.php?showtopic=175758&page=2
  6. ^that Have you tried a 60 maybe 58 pilot? What type of porting? If it's got block offs and they did a fairly high exhaust, you may be hard pressed to try and get some low end.
  7. Yes. Takes just as much money as skill though. You can compete at your current weight. There was a guy who dominated D14 in michigan a few years straight and he was a big hoss with a very insane 400 ex chassis and a pretty wild 450 motor.
  8. Just bolt on Athena or has it been ported? What type of riding? Really the stockers should suffice unless it's really been worked over.
  9. Jetting could definitely be the culprit. I assumed it was dialed in, but you said it's doing the same thing when you richened and leaned it out? What's the whole motor set up?
  10. New bearings ( do not reuse, new ones will have an O ring to keep them from spinning. If not, a dab of LOCTITE works)Weld crank Full clip for pto crank bearing Maybe mod the tranny Look over all clutch components with a fine tooth comb 1211 three bond for case sealer.
  11. Clean carbs (blow out jets and look through orfices) Clean the PV's Check ignition components Look for air leak
  12. Ok, ride better then. You've spent the years getting the chassis and motor to top dawg status. So you better bring home the trophies this year!
  13. That's because you are an ass. But that's one of the qualities I like about ya'.
  14. YES! Any one wanna buy some chariots with the overflow? I've already re soldered the overflows. Let's get these sold! I need find age for some cascades.
  15. Fucking animals running hand coned inframes on 20+ DM's. I love what is happening to the banshee scene.every 2/3 years things get way cooler.
  16. Maybe I interpreted that wrong. But for someone to say your pipe is the reason they melted their shit down, you are a better man then me to not tell them to fuggoff. All you do is produce a product. Any mis use of your product is not your liability. But there will always be know it alls who put together some rediculous combo, and when it doesn't work, it'll be your fault.
  17. Sure they do, he's huge, had chassis and motor vortex issues and dicked around with a sub par stock stroke shit pile for a few years. The 4 pokes loved it.
  18. Yes, if you climb a lot of hills I'd definitely shy away from any negative length. Maybe try a +2 or +4.
  19. Split the cases. There is no garuntee that none of that was in the low end.
  20. What was the set up? 7/8" is tiny. If I saw that I'd assume they were for some hot stock stroke 350. Anything more and you should of definitely found something different.
  21. I love a polite, yet subtle fuck you... Teuchè.
  22. Ya, that's typical of an aftermarket cast plate. Had a RM plate let go of my brand new OEM stator from the dealer like 5 years ago. Fucking stator looked like some dirty meth heads teeth. I posted pics here, so maybe you didn't look hard enough for the proof. It's a bummer you got GOT. Hopefully this helps out some folks looking for a new plate.
  23. Eww, grease? No go. That thing is trash.
  24. I like your plan, but I think you need to double your budget based on your expectations.
